315 Nittos
Old 06-29-2009, 08:17 PM
Smoke Em's Avatar
Default 315 Nittos
because nittos are narrower than a lot of tires would it be alright to fit 315s on a 9.5 inch rim
i wish they made 295 nt555's
i already read the stickies and i would not do it would any other tire but nittos because they are much narrower
does any one have the exact measurement of 315 nittos nt555's
Smoke Em is offline
Old 06-29-2009, 08:20 PM
hitmanws6's Avatar
lock this one up Xsta.
hitmanws6 is offline
Old 06-29-2009, 09:02 PM
HTh3r0's Avatar
close to 12 and half inches.
HTh3r0 is offline
Old 06-29-2009, 09:24 PM
Smoke Em's Avatar
thanks that helps alot
now im rethinking about putting those on 9.5" rim
does anyone have a measurement of 285/40/17 nittos nt555 non drag radials
Smoke Em is offline
Old 06-29-2009, 10:18 PM
NVR_SPDS's Avatar
285/40-17s fit very well on 9.5 inch wheels. As for measurement on the 315s.. Ill have some pics up shortly.
NVR_SPDS is offline
Old 06-29-2009, 10:23 PM
Smoke Em's Avatar
i know the 285s fit great
i got 285 Goodyear gsd3 and i love how wide they are out back im just hoping that the nittos are not noticeably narrower which i hear they are
are nitto 555 non radial wider than 555r
Smoke Em is offline
Old 06-29-2009, 10:28 PM
HTh3r0's Avatar
315 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel.
315mm is 12.4 inches.
why would 315mm on one tire brand be different than 315mm on another tire brand.
HTh3r0 is offline
Old 06-29-2009, 10:32 PM
Smoke Em's Avatar
i know that but trust me there is a difference in the brand name on how wide they are sumitomos are some of the narrowest tires ive ever seen. comparing 315 sumitomos and 315 goodyears they are almost and inch and a half narrower there is a pic on this site somewhere
Smoke Em is offline
Old 06-29-2009, 10:38 PM
HTh3r0's Avatar
is that compared on the same spec wheel?
HTh3r0 is offline
Old 06-29-2009, 10:54 PM
Smoke Em's Avatar
thats without rims
Smoke Em is offline
Old 06-29-2009, 11:07 PM
NVR_SPDS's Avatar
This should answer your question:
315/35-17 Nitto NT555 NON DR
315/35 Non DR on the Left, not mounted. 315/35 Nitto DR on right, mounted on 11" wheel
Non DR Mounted on 11" wheel- Left. 275/40-18 Mounted on 18x9
315/35s mounted on stock wheels... They may be 11" wide, but their stock LOL:
NVR_SPDS is offline
Old 06-29-2009, 11:14 PM
Smoke Em's Avatar
that helps alot now if i can only get a pic like those with a 285/40/17 nitto nt555
do you think that the nitto nt555 non dr are consistent with normal sizes or are they narrow like the 555r
Smoke Em is offline
Old 06-29-2009, 11:31 PM
NVR_SPDS's Avatar
If im not mistaken, they are pretty consistant. Our other car had that combo on it (275/40 front, and 285/40 rears) for quite a while. the 285s bulge slightly more on a 9" wheel than the 275, but they fit really nice on 9.5s. Sorry i dont have measurements, but theyll look good.
NVR_SPDS is offline
Old 06-30-2009, 08:20 AM
Xsta Z 28's Avatar
Read the sticky . . .
Xsta Z 28 is offline
