Heli-Coil Help
Heli-Coil Help
i just heli coiled my rocker bolt hole, i drilled it, tapped it, and put a couple "coils" in but when i tighen the bolt in with the rocker its wayyy to tight. it doesnt even make contact with the rocker and gets stuck... anyone have any suggestions?? thanks
Moderator
What kit (thread pitch) did you use? M10x1.25 is the right size I believe. If you did it right, I don't see any other reason it would just keep turning, unless it was the wrong size or the actual threads on the bolt are jacked.
I always drill it out to the larger size recommended, but not any deeper than what was already drilled. Deburr, and then tap it with the recommended/supplied tap. I'll clean it out REALLY well, and then thread in the helicoil insert to where it's a little bit below the surface of the hole. I then break off the tab at the bottom and remove it. Did you do anything different?
You used the correct size bolt and tap for the heli-coil?
Then you inserted two heli-coils into the hole? (not sure why you did this)
Are both tabs off of the heli-coils?
With the rocker off, will the bolt go in by hand (no wrench at all) until it bottoms in the hole?
I didn't see that you had put "a couple" of helicoils in the tapped hole , I think that's your problem . They come in different lengths for different depth holes . You also may have bought locking helicoil inserts . If you have anymore left look @ the middle of the coil insert and you'll see a section which is not round with little flats that grab the fastener . These inserts can be a real PITA .
