A/C help!!!
A/C help!!!
Hey guys I was wondering if someone might be able to shed some light on this for me. Up untill a 2 months ago my a/c was working fine, then out of nowhere it just stopped working and blows hot. My first thought was that mabye it just needed a charge so I bought a can of R-134a one with a guage on it. As soon as I hooked it up It was reading that it was already fully charged????
I am not sure what to do with it at this point, I am trying to avoid taking it to a a/c shop because I need to a huge repair bill. As it is I dont really drive the car, only on weekends but now it is so damn hot out i dont want to drive it at all.
Any help would be appreciated!!!!
thanks!!!!
thanks!!!!
lol same **** happened to me brought it to my guy..
he told me it was shot and about 1,000 for him to drain out install new clutch/compressor and put the freon back in.
I told him naw i rather sweat my *** off.
Tbh if ur compressor is shot its not worth it.
F that. Open the system, change the compressor, and recharge. Find someone like me that has a/c tools, or find a shop that will vacuum the system and recharge for cheap. It ain't rocket science. My guages, vacuum pump, and everything paid for itself in about 2 jobs.
Before throwing parts at it you need to find out exactly what is wrong with the system. Not to be rude but those gauges on a can aren't really worth a crap!
First off you need to find out if it is fully charged by having a decent set of gauges for high and low side. Then are you getting power to the compressor, if you are can you tap on the compressor clutch and get it to engage?
If no power, why are you not getting power, fuse, relay, pressure switch, internal pressure problem with the system, a/c control head signal???
May cost a little upfront but instead of throwing parts at it and hoping to get it right have it properly diagnosed and save a lot in the long run but at the same time find someone that is honest and not someone wanting to replace half the system for around 1K!
thanks for the info guys, can anyone reccomend a good shop in the Spring Hill Brooksville are that isnt going to rob me just to diagnose the car or am i going to get stuck paying for an hour or two of labor no matter where i go?
Just want to have someone look at it who is honest!
I know the guages on the cans from the store arent accurate, mabye the relay could be bad? I have had to replace alot of various sensors on the car, i dont know if the car sitting and not really using it has something to do with it.
thanks for the help guys!
or if anybody locally who has the tools could look at it that would be great, but if anyone knows a good shop here that works too.
Agreed. I have true a/c guages, and you can diagnose a lot from just them. The can guage is nice for recharging a known good system I guess.
Find out what you got. We can talk once you know more if you want to drive over here. I bet you find a honest shop near you if you ask around. If not, let me know.
jump your low pressure switch and see what happens. if the compressor engages and works fine then may very well be the culprit. thats what sends the signal to the compressor to activate. i learned about ac real quick with my old lt1 car. 2 south florida summers without ac.
how do you jump the low pressure switch? is it possible that the a/c relay could be bad?...... One thing i did notice is that when i was trying to fill the a/c the condensor was getting cold, but now if i turn the air on it doesnt form that condensation around it. I havent paid attention if the clutch is engaging at all i guess that is something i should look for later today.
the condensor isnt getting cold, and the clutch on the compressor seems to be engaging, I can see it spinning but it isnt making alof of noise. When I put the cheap can guage on it again it was reading in the red zone so I have no idea whats wrong? Dont know how something can work fine that all of a sudden take a crap
