New slave cylinder
New slave cylinder
Putting in a new clutch soon and i figured I might as well replace the slave too. where is the best place to get one? byunspeed has one for 175 and then another for 125. I want the 01+ model but I am not sure which one it is or where to get it.
Yeah, it should be the same thing. Go to partsamerica dot com which is advance auto's online retailer where you can basically look up parts in their system (you can even check in-store availability) or you can use oreillyauto dot com. Look up the slave cylinder for an 02 V8 F-body and cross check the part numbers with Summit or Byun. I'll bet good $$ they're the same.
Why don't you ask me FGT! i paid 148 for my c6 z06 slave instead of 250.57 from GM go to GMpartsdirect print out the price of the slave bring it to ed morse chevy and make them price match and tell them GMPD has free shipping.
-PapaCTSVCream
-PapaCTSVCream
+1 they are the same as the gm one, just go to advance http://shop.advanceautoparts.com/web...6_770356965___
not sure where youre located, and if theres even one near you, but "xl parts" is autozone and orileys distributor.. if theres one near you, you can go in there and set up a accnt with them. its free and takes a few minutes.. just make up a shop name and fill out the paper they give you.. then you will be welcomed to parts at wholesale prices! 01 gm slave cylinder is $95.00 under my shop name accnt! and yes i believe the the throwout bearing is attached and is part of the slave.. hope this helps!
Hey Zman...XL Parts is also a distributor for Advance Auto as well. Look forward to meeting you on Friday
PM coming Zman
