Question about driving in "Drive"
Hey guys,
Got another question for you all. I recently moved to an area that has a lot of twisty 35 mph roads to commute to work. I tend to put my suspension to use and carve the corners when I drive on the roads, so naturally I do not like leaving the car in overdrive during this stretch of my commute, so I put it in "D" or "Drive". I also like the fact that Drive locks up the converter at a lower speed, thus giving me the ability to directly use the torque of the engine to slingshot me through the turns while keeping a relatively low engine speed. My question is this: will I cause damage to the converter and its clutches or any other transmission component by leaving it in D while cruising between speeds of 30 mph to 50 mph on a windy road? The reason I ask is because the converter unlocks and locks a decent amount and I know the tranny was basically designed to run on overdrive 95% of the time. Please let me know as I have 85k on a stock trans with a cooler and I would like it to last.
It will cause premature converter clutch wear from locking and unlocking, and it will cause slightly higher operating temps, but if you have an aux cooler you should be fine. I personally dont see the problem with it as long as the trans isn't overheating. I mean they were made to shift gears.......
