Trex help
Trex help
What all would i absolutely need to run the Trex Cam in my M6 WS6 ??
Also i have a set of AFR Heads will fly cutting the pistons do any bad ??
Really appreciate the help guys
LS1Tech Premium Sponsor
The AFR heads have a little bit more p/v than a stock head so that should really help you. You could check p/v where your at & then decide if you need to cut the pistons.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
yea i get that alot if i had too flycut the pistons would that be bad later down the road or it dose'nt mean anything i also heard i would need bigger fuel injectors is it true?
flycutting just means u are cutting valvereleifs in your pistons witch i beleive u have to take the pistons out of the motor to do so....with u would be better off buying pistons with v/r precut...so to nswer your question it wouldn't make a diffrence down the road and im pretty sure your injectors will be fine they will just bump the injector cycle up when they tune...
