which converter for 10sec turbo car?
if you were limited to 91 octane,
which trans would you get?
i am leaning toward the th350
but will a 700r4 do?
next question,
if you were to run about 5-8 pounds boost
what stall converter would you get?
ive had a 4000 on NA
was awesome
but im thinking i could go lower
turbo might make more useable low rpm power
and all the torque might make the verter stall even higher
which trans and verter?
next question,
was awesome
ive had a 3400 before also
it was barely good enough
i guess it will do until i can get that turbokit
this is an ls1 car
4l80e is not available to me, i think.
im getting a 350 or 700 including converter for $700
im sure the 4l80e is out of my price range
if i had all the munies i think i would get a 200r4 anyway?
any reason why i should get a 400 instead of a 350???
look here
www.converter.cc
we have a full line of power adder converters and the PY 3600 sounds pretty close
but you might want to call us on Monday as our new sale starts then.
www.converter.cc
Need some more info. If this is an LS1 car, does it have the stock 4L60E? Is it an F-Body. What are you expected power levels and weigh. Depending on these answers, you can get a built 4L60E that will be able to hold the power. The 400 is stronger than the 350. I would not go 700R4, just use the 4L60E. The 4L80E is still an option, but it does get pricey.
As far as the converter. We custom build turbo converters, I know we can take care of your setup. We also have the multi disk option for WOT lock up, turbo cars love that. Stall depends on the torque curve, basically how fast your turbos will build boost. Lets get some more info and then we can get you some answers.
Chris
Chris
the car is a 96 Firebird
but it has an ls1 in it
no trans at all,
i found a deal where i can get a "built" trans with converter for $700,
i get to choose 700r4 or th350, and choose any stall speed
im not sure im going to take that deal, though..
i kinda dont want to get an unknown converter
ive had a stock verter before,
a Midwest 3400.. was better but i wanted more stall and more shift extension
got a Yank SS4000.. was a LITTLE loose for a DD but damn
i lost no race, not even to that cocky M6 driver
"ITS AN AUTOMATIC?!!" hahaha
unfortunately when my cars were apart i stupidly lent out my trans and verter to this one dude who i thought was my friend but his car got stolen, he lost his job, he gives me nothing and has nothing for me to take.
this time around im going to strip the car,
i dont know what it will weigh, hopefully 2999lbs or less
its going to be slow at first
until i can get a turbo
i plan on getting that cali-legal STS
i dont know its limitations,
but even then im going to limit the car to 91 octane
i hope to at least have a 10 sec daily driver after that turbo + fuel upgrades
"Stall depends on the torque curve" im guessing i should go moderate, like 3600 so its not stalling too high when i get the turbo?
i think i remember yank used to do that one free restall
that would be handy
or am i thinking of the wrong company?
no trans at all,
that would be handy
what would be really nice is if Yank were to cut me a deal considering i already bought a SS4000 when it first came out at like $950 or something
the car would scare people with that verter in it
they start reaching for things to hold on to
hahaha
and then i lend it out with trans cause im such a stand-up guy
only to have it stolen..
hahaha
exactly why im so hesitant. im going to see if this dude gives a warrantee for the trans. but i really dont know about that verter.. he doesnt list STR or SE.. im kinda spoiled with that 21-blade stator.. i doubt he can offer that?
so im still looking around
Im running a Yank py3600 with 5 to 8lbs on a procharged setup with a lvl 5 FLT 4l60e. If your looking to go the cheap route, Id look at a th350 cheap to rebuild and lots of parts are available.
been doing more research
why doesnt everyone use the 200r4?
doesnt it have OD, lockup, transbrake, durability?
found one "built" for $625 with stock verter
how difficult is it to get it to work with an ls1 car?
are there high stall performance converters for 200r4 + ls1?
LS1Tech Sponsor
We are currently running a special on TH400 packages.
Th400 full competition:
Full manual reverse pattern trans brake
Billet forward clutch hub
New steel direct drum
34 element int sprague
4 int clutch pack
Raybestos waffle race clutches
Teflon sealing rings
High volume pump
Modified pressure circuits
Rollerized assembly
Aluminum deep pan
New high pressure drum springs
Severe duty int snap ring
Spiral lock sprague retainer
Rated to 900 hp
1494.00
SST series 9" billet converter:
Anti ballooning plate
Furnace brazed
tig welded fins
Aftermarket custom ported stator
Heavy duty sprague
triple bearings
hardened turbine splines
chromemoly hub
billet front cover
screw on pilot
computer balanced
concentricity verified
725.00
Transmission 1594.00
Converter 725.00
Hayden cooler 49.99
Electronic speedo 95.00
Filler tube and stick 46.00
Driveshaft slip yoke 76.00
Sub Total 2585.99
Ls tech discount 5% -129.29
TOTAL 2456.70
Options:
Ultra bell installed 299.00
Vasco input shaft 325.00
Billet SFI aluminum flex plate 289.00
You will receive 5% off all accessories as well. This will be everything you need to do the swap minus the cross member .
Give me a call if you have any questions.We are running about 2-3 days to ship.
Thanks,
Greg
1-866-726-8358
4 int clutch pack
High volume pump
Rollerized assembly
Aluminum deep pan
Rated to 900 hp
1494.00
Furnace brazed
tig welded fins
Heavy duty sprague
triple bearings
chromemoly hub
billet front cover
screw on pilot
computer balanced
725.00
Converter 725.00
Hayden cooler 49.99
Sub Total 2585.99
TOTAL 2456.70
Options:
Thanks,
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
