A different cam Q. 450 rwhp 410 rwtq...NO LOPE
I currently am running a G5X2 232/240 .595''/.609'' 112...bit to peaky for my taste. Don't get me wrong, awesome cam. Just too street-drag, and that's not what the car is being built for.
I primarily use the car on the street...but as a road race street car. I live within 20 minutes of 5 amazing Utah canyons with great fast open corners and don't drive in traffic much...I want more torque.
My question is: Which cam with the Victor Jr. EFI in a road racing application? I love the way the car rev's above 5k now (a little more like the porsche flat 6[slightly] with the new Victor intake and heads)...I'll never go back to the LS6 intake or even a fast. Top end is still important to me.
The catch...Is it possible to get 450 rwhp and 410 rwtq with no or little lope N/A in a 346? The motor is in the wrong car facing the wrong direction...not many things are typical with my requests...sorry for the tall order.
I know Patrick G is the Cam God here and Thunder is an awesome place to call...but i'm looking for your ideas and experiences. I'll be contacting them soon.
Thanks, Russ
Thanks, Russ
I would shoot Predator Z a PM and see what he recommends, he is very helpful and my goals were a little less yet similar to yours. He spec'd me the cam below mated to some unworked 243s, the goal is more TQ coming in sooner and less high rev/peak up top.
230/230 .612/.592 111+2 LSA
I am looking to beak 400 RWTQ...what kind of work is done to your heads and who did it, I am debating to have my worked over before the install.
LSX Mechanic
It's possible, but you'll need a good set of heads to do it.
I've done 460/410 with a set of hand finished TEA 5.3's, and the cam had very very little lope and drove like stock.
Vengeance just finished up an X3 build (226/228) with Trick Flow 215's that made 450rwhp through a heavy drivetrain, and the X3 doesn't lope very much at all. I've installed about 3-4 of those, nice cam.
It can be done if the supporting mods are there.
did you lose any lowend with the victor intake?
Just a side note-The intake sounds much different than the LS6. Much louder SUCKING sound at idle due to IAC motor. If the car wasn't so damn loud without cat's, it would be really annoying.
I really should talk to predator Z. He seems like a nice guy. Every response i read from him seems respectful even if someone is being a douche.
I've heard lingenfelter's cams are ground to avoid lope. I might give them a call this next week.
I love lope guys...but it's a narrow body 911 and it does NOT sound right sounding like a stock car with two small mufflers a little over a foot from the heads.
Thanks guys, Any more suggestions? I'll post a little video if the rain stops tonight.
I need a UD pulley and LT's. I'm running cut off block huggers with a 3'' collector. I probably have around 15-20 wheel left on the table with these two changes.
Theres more to it than that. Look at the stock ls6 cam. It makes good topend power, but there are aftermarket grinds that match or exceed the topend while making more midrange.
The cam I had in the sig had more of a lumpy idle than lopey. I think a 230 114 +4 on xer lobes would idle noticably smoother than your current cam but the lowend wouldnt be any better. I dont know, Im not an expert.
Actually check out PatG's old set up. He had a combo that made a lot of power with a cam that had only 226 duration.
I LOVE THE VICTOR JR. Now it loves hanging out at 5500 rpm mid corner. Swapping from this intake probably wont happen.
You'll probably make better average power and still keep the high RPM feel you like with a ported FAST 92mm intake manifold and throttle body.
to the op:
what are you goals for this setup? do you know how these parts work together? using a cam with little to no lope with a single plane is bassackwards. if anything i'd say you need something like a 24x/24x on a 108 to make the most use of that single plane. you're trying to go the other way. the car won't scream above 5k with a baby cam in it, regardless of intake choice. it sounds like you'd be better off going with a lingenfelter cam and fast 92 setup, as i don't see a single plane and 118lsa cam getting along very well at all.
pm the cam guys, i'd guess they'll all tell you to change intakes first haha.
to the op:
I was really just curious if it was possible. I'm in complete agreement with the bassackwards. The car has such little weight to it that even with the current G5X2 it's got good low end at WOT @ 2500 rpm. I just wanted more, and i imagine with a well spec'd cam for this intake (which probably has a hell of a lot of lope) would yield another 10 rwhp at 6000 rpm and 20 rwtq at 3500 rpm. I know my figures are backwards and the single planes make more at the top...I WON'T BE SWAPPING THE INTAKE unless i can find someone to trade a Mamo'd fast 90 for this setup.
I'm looking for another 10-15 rwhp up top and 20 rwtq @ 3500 rpm. You're probably right that it won't happen with a single plain and a wide LSA. I'm looking for these figures obviously AFTER the UD pulley and LT's.
I'm not hellbent on #'s by any means. I'd rather tell someone it's got 330 rwhp (because it's always asked with an exhaust note like this in a narrow 911) and blow past them than work from inflated #'s. In other words, i don't care about the figure, just burning the wheels in thirdand i want more.
Not sure why your so hung up on an intake thats intended for high RPM power but yet your driving it on the street.
Will changing the camshaft to something different help? Maybe. But your still using the wrong intake for the job..period, IMO.
I really dont think its worth all the work to swap cams to gain less than you would with swapping intakes.
Again, just my $.02
Again, just my $.02
Again, just my $.02
Again, just my $.02
I'm coming from less than 200 lb. ft. of torque and the car was superb in what the car was built to do. The car was not built for drag racing and that's not what i'm trying to do. I'm just looking for more torque than what i've got with the peaky G5X2. I DON'T WANT TO SWAP INTAKES.
Cam question: What cam would yield 15-20 lbs. ft. more torque and keep the top end i've got or a little more, without changing intakes? I might rephrase the question and leave the lope part out of it.
Swapping cams takes very little time with my setup and is fairly convenient since all i need to do is pull the rear bumper and the the timing cover is right there. About 2.5 hours. Not a big deal.
