How to clean block surface?
So im about to swap out the heads on my t/a and wanted to know the best way to clean my block surface. i have a gasket scraper and an ice scraper but is there anything else i can use to get the block super clean before i put the heads on? Thanks
Yes. The biggest issue with the aluminum heads and block is people using cleaning tools or techniques that are too abrasive, and will actually mar the sealing surface. Take a wire cup brush for instance. Great for knocking rust off things, but take it to some aluminum,and you can pretty much count on buying a new block or head. DO NOT USE A WIRE BRUSH ON ALUMINUM.
