Upgrading my carb
Upgrading my carb
My carb needs a rebuild and since we dont have renew kits or anythings for Holley carbs in my country I will make an order for some parts the carb is 750 double pump with unmatched nozzles,jets,damaged power valve you name it so I was thinking of going with HP main body that has no chocks and going from 30cc to 50cc Accelerator Pump is this worth it? and I will order nozzles,jets,new rebuild kit what else do you suggest? the carb is for 383ci,Brodix track 1 heads,victor jr intake,big ***** thumpr cam and all bolt ons so be my guest to suggest the best parts for my carb to match my set up
6 & 8 Second Club
For some quick free advice. Send an email to 3-4 of the carb guys & fill in their ?? sheet.
With that info, you can judge which is the best combination for you toy.
You might need a 700, you might need a 850?? They are usually pretty accurate of the combination needed,
with the proper information in hand.
Good luck.
okay so I will just order the jets,rebuild kit and Holley HP main body
mrdragster1970 I will send Holley an email now and see what they suggest for my car
ZONES89RS as usual you were very helpfull thanks for your help and everybody else thank you so much
