Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Upgrading my carb
Old Jul 16, 2009 | 09:02 AM
F-Body Lover's Avatar
Default Upgrading my carb
My carb needs a rebuild and since we dont have renew kits or anythings for Holley carbs in my country I will make an order for some parts the carb is 750 double pump with unmatched nozzles,jets,damaged power valve you name it so I was thinking of going with HP main body that has no chocks and going from 30cc to 50cc Accelerator Pump is this worth it? and I will order nozzles,jets,new rebuild kit what else do you suggest? the carb is for 383ci,Brodix track 1 heads,victor jr intake,big ***** thumpr cam and all bolt ons so be my guest to suggest the best parts for my carb to match my set up
Old Jul 16, 2009 | 09:07 AM
yeah and another thing some guys told me to cancel the power valve and the others warned me not to do it what advantage I will get if I canceled the power valve?
Old Jul 16, 2009 | 05:00 PM
ZONES89RS's Avatar
In-Zane Moderator
The power valve is not needed unless you drive it, for a race car, ditch it. For a street car, keep it.
Old Jul 16, 2009 | 05:34 PM
ok what about the HP main body? 50cc accelerator?
Old Jul 17, 2009 | 10:28 AM
fleetmgr's Avatar
Originally Posted by F-Body Lover
50cc accelerator?
If you aren't having a stumbling problem, I can't see that this would do anything for you, except waste fuel.
Old Jul 17, 2009 | 10:46 AM
mrdragster1970's Avatar
6 & 8 Second Club
For some quick free advice. Send an email to 3-4 of the carb guys & fill in their ?? sheet.
With that info, you can judge which is the best combination for you toy.
You might need a 700, you might need a 850?? They are usually pretty accurate of the combination needed,
with the proper information in hand.
Good luck.
Old Jul 17, 2009 | 11:47 AM
ZONES89RS's Avatar
In-Zane Moderator
The 30cc acc pumps should work very well, the HP main body is great, the proform unit might save some money and is just as good.
Old Jul 17, 2009 | 12:27 PM
okay so I will just order the jets,rebuild kit and Holley HP main body
mrdragster1970 I will send Holley an email now and see what they suggest for my car
ZONES89RS as usual you were very helpfull thanks for your help and everybody else thank you so much
Old Jul 17, 2009 | 03:05 PM
ZONES89RS's Avatar
In-Zane Moderator
NP, i use 570s for my 383 and they work very well, i built my own DP 750 with the pro form main body and the quick fuel base plate, thing is sick, doesn't like low revs with a manual trans, but what big cammed car with no gears does.
Old Jul 17, 2009 | 04:20 PM
can you please give me part numbers of things that you suggest for my carb? I was thinking of Holley HP main body intead of the Proform
Old Jul 18, 2009 | 12:40 PM
ZONES89RS's Avatar
In-Zane Moderator
Either one is the same really, the Pro form jiust saves 10 bucks or so since it doesnt say holley, the PNs i used are:
Pro form main body: 67100C
Hollry main body: 134-300C
Pro form bade plate: 67155
ZONES89RS's Avatar
In-Zane Moderator
