Real Bad Vibration
Real Bad Vibration
I had a 93Z28 with a 383 and D1 Combo, It had a bad vibration after the motor install, which I never drove much then tore it apart.
I recently bought a 95Z28 with a bad T56, missing 2nd gear. Other than that, no real problems or vibrations. I swapped the T56 out of my 93Z28 into this 95, and now I have this horrible vibration, starting at 40 its vibrating the center console around, and it just gets worse, at 100 it feels like the cars coming apart. The car is lowered with Eibach Pro kit, stock driveshaft, LS1 rear end with LS1 brakes front and rear.
Its not the driveshaft as it wasnt vibrating like this till I swapped transmissions, still, I jacked the rear of the car up and pulled the rear tires off, and ran the car with no rims and tires, same vibration from 40 and up. shaking the car around.
I checked the Tailshaft bushing, and there is slight movement in the driveshaft where it goes into the back of the T56, wear in the tailshaft bushing is what Im guessing, but would this slight movement cause so much of a vibration in the car? It has to be in the transmission.
I forgot to mention, when this trans was in the 93 with the stroker, I twisted 3 LS1 Aluminum driveshafts in half, slamming them around under the car, Im wondering if this bent the mainshaft in the trans...
Anywho, any help would be appreciated..
Thanks,
James
Thanks,
James
Thanks,
James
Thanks,
James
Well, we can eliminate alot of things real easily.....when you first got this car (the 95) and you went and drove it, and you got it up to speed, right? No vibration, right? And then you pull the tranny out, and put in YOUR tranny, and THAT WAS IT right? No driveshaft swap? Flywheel? Clutch swap? Etc....JUST the tranny? If so, then yeah, something is bent internally (probaly teh mainshaft like you think) and since you are saying there IS some slop @ tailshaft bushing, etc....
Yes, just the trans, and the trans mount were changed.
I guess I know its in the trans, my question is is this a common problem for a Mainshaft in the trans to be bent, as Ive not heard of this before? Also, ive done alot of reading on vibrations in these cars, and the Tailshaft Bushing keeps coming up, my question is would the tailshaft bushing be the culprit for such a bad vibration, or would it just cause a minor vibe..
Thanks,
James
Thanks,
James
Thanks,
James
No, it is not common. People DO upgrade to teh Viper shaft, but you really do not hear much from people that bend the mainshaft. But, by you breaking/snapping a few DRIVEshafts, and they bounce around once snapped, ANYTHING could have happened, and a damaged output/mainshaft is one of them.
I would doubt the mainshaft is bent. I would start with the front U joint of the driveshaft if it were me. Also inspect the splines on the yoke and look for a twist in them about half way down the yoke.
