Harness Black Tape Source ?
Old 07-21-2009, 09:28 PM
aknovaman's Avatar
LS1Tech 10 Year
Default Harness Black Tape Source ?
Any good sources for harness black tape as electrical tape gets too gummy?
Old 07-21-2009, 10:03 PM
bczee's Avatar
check out some of the restoration site (YearOne, Ground Up, OPIG, LMC).. they all carry harness warp tape like the oem factory.. but why not use the plastic sleeving harness or what i've seen now, which i like but is bit costly.. Black ‘Wrap-It™’ Wiring Harness Sleeving by Russell
http://www.russellperformance.com/mc/acc/misc.shtml
Old 07-21-2009, 10:29 PM
loweredd's Avatar
That wrap-it looks nice! I might have to try that if I get mine running ever.
Old 07-21-2009, 10:40 PM
poconojoe's Avatar
That looks like it is just slit conviluted tubing like they use from the factory, which you can buy cheap from places like Waytek wire
Old 07-21-2009, 10:46 PM
loweredd's Avatar
Looks to me like clothwrapped. Clothwrapped look anyway.
Old 07-22-2009, 12:14 AM
bczee's Avatar
I have seen some samples of it at the Good Guys vendors booths.. Yeah.. it is like cloth like or some factory stuff..
Poconojoe, I have not researched if it is like any other product, but if as you say and its cheaper.. I'm for that ! I was just trying to let AKNovaman know that there is options.. and I do like the looks of it.. easy to use too.
Old 07-22-2009, 05:17 AM
poconojoe's Avatar
I looked Waytek doesn't sell the slit stuff, but I know I saw it in somcebody's catalog. i found a better picture, its not the conviluted style tubing, it looks more the harnesses from the 50's cars, except they looked like some kind black tarry material. I'm all for buying it for less too. 90% of Russel's products are somebody else's products repackaged
Old 07-22-2009, 06:46 AM
fmowry's Avatar
I use this high temp silicone rubberized tape in place of heat shrink tubing and electrical tape. It might get a bit pricey if you're taping the whole harness, but it isn't sticky from glue, as it adheres to itself.
High-Temp Self-Fusing Silicone Rubber Tape Triangular, 1"
http://www.mcmaster.com/#7643A281
Frank
Old 07-22-2009, 02:24 PM
poconojoe's Avatar
Here is a simular product, thats a little cheaper, but still pricey, if you're wrapping a whole harness
http://order.waytekwire.com/productd...SHRINK%20TAPE/
Old 07-23-2009, 05:38 AM
Pop N Wood's Avatar
Eastwood sells that stuff
I much preferr the mesh wrap for wiring. It is cheaper, easier to use, looks better, if you get the slit type allows you to add wire easily. I used the slit type with velcro wire wraps I got at a local home store.
Summit and Jegs sell it, but McMaster Carr is probably the ultimate source.
http://www.mcmaster.com/#sleeving/=2v9l5w
http://www.jegs.com/p/Russell/Russel...48918/10002/-1
http://www.jegs.com/p/JEGS/JEGS-Flex...59804/10002/-1
Whatever you do don't use the cheap plastic convoluted tubing from the local parts store. You need nylon tubing, not plastic, if you want it to last a number of years.
Old 07-23-2009, 02:26 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
casperselectronics.com
they should have what you want.
http://www.casperselectronics.com/st...roducts_id=687
Old 07-23-2009, 04:18 PM
aknovaman's Avatar
LS1Tech 10 Year
http://www.tapebrothers.com/Black-Dr...-p/dvt76b2.htm
http://www.findtape.com/shop/product...=1250&height=0
http://www.parts-express.com/pe/show...number=080-525
https://www.tselectronic.com/vanco/s...cde0dd2a17f43c
http://www.cabletiesandmore.com/blackloom.php
http://www.allelectronics.com/make-a...-Tubing/1.html
Old 01-27-2010, 05:35 PM
jbal's Avatar
check out ebay. "vinyl non-adhesive tape "
Old 01-27-2010, 07:04 PM
aixgelo78's Avatar
thanks..... needed these
Old 01-30-2010, 11:01 AM
aknovaman's Avatar
LS1Tech 10 Year
$3 per roll
http://rjminjectiontech.com/?p=15
Old 01-30-2010, 11:48 AM
TipsyMcStagger's Avatar
Just another source...I've used this a lot on motorcycle projects.
Tipsy
Old 01-30-2010, 02:15 PM
dsrour's Avatar
The split braided Nylon covering I've found works well and looks good too.
"F6" is the brand name I've used. Reasonably priced in bulk.
Need to heat cut. I use a soldering gun or a microtorch.
http://www.parts-express.com/pe/show...ource=googleps.
Many vendors sell it including Waytek
I've found using harness tape where wires exit loom works well. At ends can use heat shrink tubing or for stepping down to a smaller size.
Quick Reply: Harness Black Tape Source ?
