Suggested gears for this set up?
Old 11-17-2003, 11:28 PM
TNormZ28's Avatar
Default Suggested gears for this set up?
All bolt on's, LS6 cam, true duals w/ Xpipe, 3500 stall TC. I'm thinking of doing 3.73's or 4.10's. All will be tuned. I will be running no more than a drag radial. thanks.
Old 11-17-2003, 11:32 PM
STF veteran / 10 second club
x phantom x's Avatar
If you plan on a power adder like nitrous, and no bigger tires (like you said), then go with the 3:73's.
If you are not going to go with a power adder, you would be better off with the 4:10's.
4:10's will allow you to run like a raped ape on the street, but you will run out of gear around 115mph at the track (on stock tires) ... so if you plan on trapping higher then that, go with a numerically smaller gear, such as a 3:90 or 3:73.
Old 11-18-2003, 07:23 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Yeah, Phantom, I have to shift at the traps.
SS, are you A4 or M6?
A4 = go 3.73
M6 = go 4.10
Old 11-18-2003, 10:10 AM
BlackBowtie's Avatar
I believe he said he's got a converter, so I'd go 3.73's
Old 11-18-2003, 10:19 AM
Oh yeah look at that ... def go with the 3:73's. ..
Old 11-18-2003, 11:18 AM
TNormZ28's Avatar
Cool. I was leaning towards 3.73's. Do you know what the rpms will be cruising at about 70-80 on the highway? And is there any need to upgrade to an Eaton posi unit. Again, I won't be running anything more than a drag radial and this is a daily driver. thanks or all the info.
Old 11-18-2003, 02:37 PM
onebadz's Avatar
One the highway @ 70 I turn about 2300 RPMs. I still get good gas mileage about 20MPG
Old 11-18-2003, 03:01 PM
OneBadz's got it... thats right where I used to run with my old A4.
Unless you are going to add some serious power or run slicks your auburn unit should be fine.
Old 11-18-2003, 11:10 PM
TNormZ28's Avatar
ordered 3.73's today. We'll see what happens. Thanks for all the input.
Old 11-19-2003, 06:27 AM
samz28's Avatar
I got GM 3.42's. The diff between 3.42 and 3.73's aren't much but strength was a concern. However i have now learned that no matter what you will destroy your rear end so i spose it doesn't matter. plenty of 11 second 3.42 rear end cars (in texas, lol).
Old 11-19-2003, 09:10 AM
!LS1 11 Second Club
Shoulda gone 3.73 IMO. If it's not too late get 'em.
Your rear end, as an A4 suffers less abuse than M6 rear ends.
Old 11-20-2003, 03:35 PM
B-MAN's Avatar
