Strange leak issue....expert inside please
01 A4(2wd truck), 2400 fuddle stall, no internal mods, trans tuning done by blackbear.
The trans will be fine for weeks on end, drive it around on short and extended trips, no issues, no leaks. Car will sit for a week or so, I will get a puddle under the car. Puddle is coming from the small inspection hole in the bottom of the trans. I will add fluid, check level, drive, no leaks. Car will sit for several days, no leaks, drive it some more, no leaks....then out of the blue after the car sits for a week, I will come out to find another puddle. Sometimes the puddles are a half a quart or more....I just cant figure it out....thoughts?
Jack
Jack
Man this is weird! I have a friend with a Turbo 350 in his Olds Cutlass which is been doing the same thing for years. Nobody can figure it out. I'm starting to think maybe the dipstick or tube is the wrong length and we are overfilling it?? Thats my last idea since every seal or gasket has been replaced. Its one of these deals............
