Competition TFS 215 vs new AFR 215 heads !!
new release 215 version from AFR
215cc LSX Mongoose Street Aluminum Cylinder Head
http://www.airflowresearch.com/lsx-215cc-c-10_115.html
and
Trick Flow Cylinder Head 215
who Winner ??
and
who Winner ??
this would be great. since the tfs heads are supposed to make more power up top then the afr 205's but now with the 215's it might be equal but with the afr's you wouldnt have to buy the roller rockers
LS1 Tech Administrator
From what I've heard, the new AFR 215 heads will work very well on a 3.900" bore. Lessons learned over the years have shown that a combustion chamber slightly larger than the bore gained more power on a 3.900" bore than running a 3.900" chamber. For what it's worth, the TFS 215 heads also run a larger combustion chamber than 3.900". We all know that the TFS heads make excellent power. A head to head shootout in the future will be fun to watch.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Tfs 205
intake - exhaust
0.100 66 52
0.200 135 109
0.300 203 165
0.400 257 209
0.500 287 222
0.600 299 237
Afr 205 cc
0.200 140 112
0.300 200 170
0.400 251 203
0.500 281 221
0.550 292 226
0.600 298 230
Tfs 215
0.100 68 55
0.200 142 155
0.300 215 185
0.400 269 230
0.500 305 251
0.600 320 259
Guess numbers flow
AFR 215
0.200 147 158
0.300 212 190
0.400 263 224
0.500 293 250
0.600 319 252
intake - exhaust
0.100 66 52
0.200 135 109
0.300 203 165
0.400 257 209
0.500 287 222
0.600 299 237
Afr 205 cc
0.200 140 112
0.300 200 170
0.400 251 203
0.500 281 221
0.550 292 226
0.600 298 230
Tfs 215
0.100 68 55
0.200 142 155
0.300 215 185
0.400 269 230
0.500 305 251
0.600 320 259
Guess numbers flow
AFR 215
0.200 147 158
0.300 212 190
0.400 263 224
0.500 293 250
0.600 319 252
If you read the "recipe for 500hp" and other threads that detail the hand porting work that Tony Mamo has performed on AFR 205 heads, much of the details have been covered there...
Just a guess, but I'm betting that alot of what Tony did to hand tweak the 205cc heads for Patrick's 500+ hp 346ci build, and the 403ci engine for Roy's GTO has been applied to a new CNC program that comes close to duplicating his efforts. Maybe that is not the case, but I recall quite a bit of interest in the performance potential that Tony was able to wring out of the heads.
If 95% of the potential from an AFR 205 hand ported by the port designer becomes available for CNC prices, it's a great thing for the LSx performance market.
UNDER PRESSURE MOD
Well, I admit when I'm wrong. I was just referencing the AFR website where it states that the heads require a minimum head gasket bore of 4.135". I figured that if the head gasket is required to be that big, its because of the location and size of the intake valve and would make sense that the cylinder bore needed to be that size as well.
2.) Look at the size of the port. Volume is about all that most people will publish, but Cross Sectional Area can vary quite a bit as well. If possible, verify that the port measures out to the rated specs.
Interesting Flow Data
If you haven't read the thread from the sticky at the top of the forum, you owe it to yourself to look it over. Every vendor knows that peak flow numbers sell heads. Short of that, it becomes pretty tough for the consumer to make comparisons.
While most people in the community are honest, indepedant testing has shown that several variables can effect the actual airflow. Weak test springs, generous port volumes, happy flow benchs and skewed dyno numbers can all become great marketing devices. In the end, the results at the track are the only equalizer. Even then weather conditions and vehicle and track preparation vary.
