What type of brake setups do you use?
Old 07-25-2009, 12:29 PM
IT_SS's Avatar
Default What type of brake setups do you use?
A lot of people who post in FI have amazingly fast and powerful cars, so assuming you built from the bottom up (suspension/handling --> power plant) I'm curious to know what kind of brake systems you all use for a point of reference. So if you don't mind sharing, please post RWHP and brake setup!
Old 07-25-2009, 06:38 PM
MY99TAWS6's Avatar
Sorry no dyno numbers yet. Estimate 600 to 650 rwhp at current boost plan on 1000rwhp max but still think stay at 700rwhp or so for general street driving.
I have just ls1 brakes with kvr rotors and kvr pads upgrading shortly to c5 z06 calipers ,rotors and pads in front and c5 calipers and pads in back. Stainless lines.
And for sure you want to have good brakes.
Old 07-25-2009, 06:41 PM
cablebandit's Avatar
800+ stock
Old 07-25-2009, 10:18 PM
'Trust''s Avatar
#'s in sig, stock calipers, Hawk pads and drilled/slotted rotors. They really don't make a kit with much more clamping force than stock that will fit inside my wheels, or I'd have something else.
Old 07-26-2009, 06:57 AM
Phat69's Avatar
mustang hydroboost setups can be had pretty cheap if you are keeping power steering.
Old 07-26-2009, 01:30 PM
IT_SS's Avatar
Originally Posted by cablebandit
800+ stock
Really? No special pad/rotar combo?
MY99TAWS6, I've been looking into a C5 Z06 brake setup and so far all I see are front conversion kits, am I to understand the the rear brackets don't need to be modified?
Old 07-26-2009, 01:41 PM
dudeman's Avatar
500-550ish, its going on the dyno this week. stock brakes with rayabestos quiet stop pads. as far as suspension goes its all stock except kyb agx shocks and a umi torque arm.
Old 07-26-2009, 01:55 PM
MY99TAWS6's Avatar
Correct..front requires c5 or c5 z06 calipers and pads and rotors . I got umi conversion brackets.
Backs you simply use c5 or c5z06 caliper and pad and f body rotors. no conversion brackets.
hearing some diff on front lines..some say ls1 ok some say to use c5 but they are way long. I have stainless lines now f body lines forget if earls or russel so not sure how they will work gess have to see.
Old 07-26-2009, 02:30 PM
Coal Mining Director
onfire's Avatar
Stock calipers front and back. Baer Eradispeed stock diameter rotors front and back. Hawk pads. Stops 4000lbs at 155mph easily.
Old 07-26-2009, 02:44 PM
The Beast's Avatar
ABS delete, braided SS lines, drilled and slotted rotors, Hawk HPS pads, plus RX7's come from the factory with 12'' rotors and 4 piston calipers Should be in the 1000rwhp range
Old 07-26-2009, 04:47 PM
IT_SS's Avatar
Thanks guys
Old 07-27-2009, 10:49 AM
Cobra Commander's Avatar
Stock/stock replacement stuff. I'd rather spend money elsewhere.
Old 07-27-2009, 10:53 AM
Fireball's Avatar
strange front conversion kit
wilwood dual rear calipers
ALOT of RWHP
Old 07-27-2009, 12:51 PM
dreamls1's Avatar
673whp Stock front and rear brakes/calipers/rotors.
Quick Reply: What type of brake setups do you use?
