Can a maxed out 4L60E handle 770RWHP in OD?
Old 07-26-2009, 03:43 PM
'Trust''s Avatar
Default Can a maxed out 4L60E handle 770RWHP in OD?
Assuming a 4L60E was built as much as it could be (w/5 pinion planetary's, so I guess 4l65e) with all the goodies, converter built to handle the power weight etc. Can it survive shifting into OD under WOT with as much RWHP as my car makes?
Old 07-26-2009, 04:41 PM
2000SS1979's Avatar
I would like to see some responses on this also.
Old 07-26-2009, 06:43 PM
AutomagicLS1's Avatar
I'd have to go with negative
Old 07-26-2009, 06:47 PM
LS1Tech Sponsor
performabuilt2's Avatar
it will be putting alot of load on the band it depends on the rear gears I would say
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 07-26-2009, 06:50 PM
LS1Tech Sponsor
performabuilt's Avatar
Cna it be built to hold up a while Yes. Would be IMO very reliable long term combo. Probably not would require a redo here and there.
If I did go that route I would get one with a LONG warranty for sure no matter where you get it from.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 07-26-2009, 10:36 PM
built408's Avatar
I would say yes, as long as it has a billet 4th servo and a good band/drum. Is it going to last forever, no. What gears are in the rear and why do you need to shift to 4th at WOT? What converter is in it? Triple Disk?
Old 07-28-2009, 11:02 AM
'Trust''s Avatar
I haven't ever shifted it into OD, but I'm just talking about for highway runs, it doesn't see OD at the track. It has 3.73's in the rear and a Vig 3200 triple disc. I don't expect it to hold forever, no, but I also don't want it to let go after doing it twice ya know?
I don't really street race much, but for those races that are close and require the extra 20 MPH I'd like to be able to use OD.
Old 07-28-2009, 11:20 AM
Double-L's Avatar
I would say no problem, I have a 04 SSR that weighs 4980lbs. with fuel and me in it and have a built 4L60 running a alky injected, Super charged LS6 stroker with all the best parts, I have had a 1.55 60ft. and run a best of 11.55 and after 4 years and 100's of runs down the 1/4 mile and driving it on the street I had the guy that built it check it out and he said it looked good just normal ware and I am not running a forged forward drum, Also have a Vig 3200 triple disc in mine
Old 07-29-2009, 09:07 AM
cablebandit's Avatar
i would say no....for the cost of the frequent rebuilds of a 4l60 you would be better off getting a 4l80 like mightymouse and I have. You will then have a tranny that will be damn near bulletproof.
Old 07-29-2009, 06:37 PM
'Trust''s Avatar
Mine is fine in 3rd all day long on a track day and on the street, does yours see overdrive much though?
Old 07-29-2009, 07:59 PM
lfsglass's Avatar
You should PM "JUNK" he has a C6Z w/ the 4l60e auto swap.....he builds these transmissions and he can tell you what can be expected.
Old 07-30-2009, 08:27 AM
2001WS6Vert's Avatar
At your power level I would just get an 80. My fully built 60 went out on the first pass when I reached 770 rwhp. The 80 feels like it's ready to take anything I can throw at it.
