ls6 intake swap question
I just purchased a ls6 intake and 80mm tb
I'm going to be doing the ls1 to ls6 intake swap on my 00ws6 tommorow
from what I've read I just need to be careful removing the intake so I don't damage the oil sending unit and block off the egr with block off plates
and I'll prob replace the gaskets since I'm going to be their.
The only question I have is can i reuse the coolant hoses or do I have to upgrade to 01 hoses,and also I think I have to grind something down on the intake. Any help and info would be helpful thanks.
anyone have any ideas on hp gain for both intake and tb upgrade?
http://www.ls1howto.com/index.php?article=5
One thing they don't tell you is to use rubber bands on the rear 4 bolts (2 per side) to hold them in up while you remove and install the intake. It'll save you a little headache
