Nitrous OutLet direct port system
Old 07-27-2009, 02:33 PM
PONTIAC SLP's Avatar
Default Nitrous OutLet direct port system
hi , i seen two direct port systems from Nitrous Out Let 60PSI , i want to know what is the difference between 2 solenoids and 4 noids
Old 07-27-2009, 03:23 PM
DopdBrd's Avatar
Really no difference I don't think. Just depends on how you set it up. I'm going 4 noids but that is only because I am doing rails that each need a fuel and nitrous solenoid.
Old 07-27-2009, 04:32 PM
can i run 400HP with 2 solenoids direct port system ?
Old 07-27-2009, 05:56 PM
DopdBrd's Avatar
As long as the solenoids that flow well enough I don't see a problem. Ask someone from Harrisworks or Nitrous Outlet. Both are very helpful and will be able to give you a definite answer.
Old 07-27-2009, 06:03 PM
Xtremespeed's Avatar
Most will recommend a 4 solenoid setup for a shot that big.
Old 07-27-2009, 06:59 PM
dnkynrbk's Avatar
Im running the N20 OUTLET D.P. 2 NOID They are good up to 400 hp no problem if your spraying a 400 shot you better have hell of a motor lol.
Talk to DAVE or Chris man they will get you set up on what you need for your application. They did an awesome job on mine and had it sent back to me within a 2 week time frame for me to go race. And the hard lines look sick when you open the hood and are all pefectly lined up.
Old 07-27-2009, 07:00 PM
dnkynrbk's Avatar
Man im runing low pressure 10 psi with their dedicated. Currently tunning the 250 shot then moving up to the 300.
Old 07-28-2009, 11:25 AM
Chris@NitroDaves
Guest
Posts: n/a
The 2 noid setup has one nitrous and one fuel solenoid that are attached to a common distribution block which then distributes the nitrous and fuel to both sides of the motor. The 4 noid setup has a nitrous and fuel noid for each side of the motor without having to go to a common distrubtiuon block.
Yes
Old 07-28-2009, 02:54 PM
Z284U2TRY's Avatar
Wowsers those noids flow 400? What is the orfice size on the n20 noid?
Old 07-28-2009, 05:26 PM
Chris@NitroDaves
Guest
Posts: n/a
.125 and in the Direct prot form you can spray a potential 500HP with our 2noid setup.
-Chris
Old 07-28-2009, 11:49 PM
dnkynrbk's Avatar
Hey chris I still need to get your shirt to you......
Old 07-29-2009, 02:22 PM
Chris@NitroDaves
Guest
Posts: n/a
Thats right....I had forgetten about the Shirt .
I need the Porno Size XXXL ( Aka: Fat **** size ) in case you had forgotten.
Old 07-29-2009, 06:29 PM
FastBlackTA's Avatar
I used a 400 shot on Dave's two solenoid system with no problem.
Old 07-29-2009, 06:33 PM
when you purchased your direct port system what jets the system include ?
Old 07-30-2009, 12:00 AM
dnkynrbk's Avatar
It cam with 100 200 300 400 jets. I also called Dave and bought the 250 jets extra so I could tune the 200 then go to the 250 see how that goes then up to the 300 to just be safe. I just started with the 250 jets.
