Is A LS1 Throttle Body Block-Off Necessary???
Old 07-29-2009, 12:13 PM
LS1GMCTruck's Avatar
Default Is A LS1 Throttle Body Block-Off Necessary???
On a 2001 F-Body LS1 throttle-body, is blocking off the ends of the pass-through heating tube, for cold motor start-ups, really necessary? This is'nt a potential source of a vacuum leak, is it? (I have the usual reroute to the radiator)Thanks
Old 07-29-2009, 12:15 PM
Moderator
jimmyblue's Avatar
It's just a straight-through channel, does not see
intake air. I cut the whole boss off mine, nipples
and casting, with a hacksaw for clearance.
Old 07-29-2009, 01:37 PM
bczee's Avatar
I did the same, well.. I broke mine off trying to twist them out.. LOL.. or you can just plug them.
Old 07-29-2009, 07:30 PM
Thanks guys.
Old 08-03-2009, 12:18 PM
Rodder's Avatar
And that's not for cold starts... it's to prevent icing in cold weather.
Old 08-03-2009, 12:29 PM
99'CajunFirehawk157's Avatar
So you left the holes open or siliconed for appearance purposes?
Old 08-03-2009, 12:49 PM
Nashty's Avatar
I cut the whole thing off completely. It interfered with my Magnacharger water in / outs.
Quick Reply: Is A LS1 Throttle Body Block-Off Necessary???
