MS3 Cam Stock Rod Clearance
Hi, I kinda new to LSx motors. I was just wondering if a MS3 cam would clear the stock connecting rods? The specs on the cam are 237/242 .603/.609 112 Degree. I'm building up an LS1 for my 92 firebird and plan on keeping the motor stock besides the cam, valve train, and I'm going to buy the Edelbrock carb kit. I will put on headers when I get more money.
Any help would be appreciated!
Thanks
Thanks
+1
Somewhere I read a review that said the MS3 was designed to give the biggest gain of any cam swap to an other wise stock LS1. Meaning no special pistons or shorter rods to clear the valves.
Piston to valve clearance might change but a MS3 or any cam made will not reduce the cam to crank clearance. The base circle gets smaller on larger cams and not the lobe getting bigger so you don't have to worry at all.
Now you run a 4.250 stroke and things get closer.
LS1Tech Premium Sponsor
^^Erik nailed it. Always a good idea to degree in these large camshafts as well, even on stock engines that should have sufficient piston to valve clearance. Lately we've had a handful of customers calling saying we owe them engines because they installed the camshaft off a tooth. After install and before firing, always good to verify your piston to valve clearance as well!
But on yours, connecting rod to cam clearance will not be a concern.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
It happens more often than you'd think, sadly.
__________________
