front lowering springs
Old 07-31-2009, 06:31 PM
spaulsen's Avatar
Default front lowering springs
i want to lower the front but leave the rear alone.. i need to know if you guys think 1in in the front will look right, or should i go more? and if more, how much?[IMG][/IMG]
Old 07-31-2009, 07:10 PM
02TransAm/Batmobile's Avatar
I think Strano's 1.2" drop would look perfect on your ride. I don't know if he separates them though?
Old 07-31-2009, 10:44 PM
spaulsen's Avatar
free bump....anyone else
Old 07-31-2009, 11:32 PM
KILLER-LS1's Avatar
ill be selling just my front hotchkis springs next week. PM me for more info
Old 07-31-2009, 11:49 PM
Intercooler2's Avatar
So you want to use stock springs on the rear? It won't ride right. At least mine didn't due to different rates.
Old 08-01-2009, 08:03 AM
spaulsen's Avatar
the reason i want to leave the rears alone is because if i drop the rear it will be sitting on my tires.
Old 08-01-2009, 10:24 AM
If all you want to do is drop the front. Couple of options first is lower perch on Konis... no change in ride. Second would be to do the SLP 1LE springs I believe they are called... which don't have a huge drop or high rate.
Old 08-03-2009, 06:33 PM
bowman2005's Avatar
If you do decide to drop the front let me know because I have a set of bmr 1" lowering springs brand new in the box.I will take $120 for them shipped.
Old 08-04-2009, 07:23 AM
UMI Sales's Avatar
Hello
I've seen some rides with the Eiback pro kits on the fronts or a coil over set-ups is nice as well (gives you the adjust ability to lift or lower) those are just a few other options as well.. If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Old 08-04-2009, 10:28 AM
BMR Tech's Avatar
That's a nice deal for fronts only
Old 08-04-2009, 11:40 AM
bowman2005's Avatar
Yes I think so to,I paid a little over $150 for them and never used them because I race alot so I just went QA1's.
Old 08-04-2009, 01:13 PM
UMI Sales's Avatar
When it comes to racing the QA1's are really good for weight transfer ( as long as you get the correct spring rate).
Take it easy
Brad
Old 08-05-2009, 04:52 PM
spaulsen's Avatar
Originally Posted by UMI Sales
Hello
Thanks
Brad
whats a coil over settup cost to my door? ( 43055 )
Old 08-07-2009, 07:49 AM
bowman2005's Avatar
I just paid right at $550 for my QA1 setup.
Old 08-07-2009, 08:03 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
I can get you a set of QA1 single adjustables with whatever spring rate you need delivered to your door for $530.21. If you want the R series drag race version it would run you $510.21. Give me a call if you have any questions or would like to order a set.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 08-07-2009, 09:57 AM
UMI Sales's Avatar
Hello
It really all depends on if you want single or double adjustable shocks! Leave me know and I will be more than glad to get you a quote!
Thanks Again
Brad
