Finished my Hot Side today. GETTING CLOSER!!
Spent a portion of the fabbing up my hot side for my front mount, thought it turned out pretty decent considering I am using a 110v Lincoln with no argon, plain old .035 flux wire. Only thing left I gotta do is weld on my wastegate, coat it and wrap it.
Be easy on my welding skills people! Getting a few steps closer. Hopefully have the motor back in sometime this week so I can start on my cold side.
So with the weld right next to the hole in the flange like that how do you plan on putting a bolt through there and having it sit flush? Obviously the bolt head or nut is larger to than the hole. are you going to tap the flange or what?
If you are refering to the pass side flange, instead of using a stud I am going to install a 3/8" bolt about 1.5" long from the other side (manifold side) and use a header locking washer and nut. Fits like a glove.
