Question about power drop off
Old 08-02-2009, 08:39 AM
O1ws6's Avatar
Default Question about power drop off
I have the sts kit and the trt fmic, 42#, fuel pump, dual springs stock motor. Turbo is the ar 60-1 @ 10psi. Made 461hp and 480tq with an auto... But just after 5k rpm the engine droped power. The turbo still put out full boost. Is the stall the issue with this setup (going bad?). Never passed 85 duty on the injectors and iac was around 85-90 also PCM never pulled timing out. Thanks for any insight I recivie on this.
Old 08-02-2009, 10:31 AM
98Camarod's Avatar
What trans/converter setup do you have?
Old 08-02-2009, 10:54 AM
OUTLAWZ RACING's Avatar
Turbo Is not going to carry that far your pretty much max it out. A good upgrade will be a mpt70
Old 08-02-2009, 10:56 AM
98Camarod's Avatar
lol, I thought he had the 70, misread it
Old 08-02-2009, 11:01 AM
Yeah the 60-1 is boo boo I had it when I first got my kit and after a month I got the upgrade at the time to the 67 from sts. My boy is eying your e bay kit Im sending him to your thread nice job by the way.
Old 08-02-2009, 11:32 AM
98Camarod's Avatar
thanks, I'll be putting in a th400 here shortly Tell him to just pm me if he has any questions
Old 08-02-2009, 11:41 AM
Restricted User
98Z28CobraKiller's Avatar
He says that it is dropping power but not boost. If it is holding the boost solid, the power shouldn't be falling off. I thought that an undersized turbo would loose boost as it can't keep up with the volume of air that the motor is ingesting. He may be blowing out spark.
Old 08-02-2009, 12:45 PM
O1ws6's Avatar
Gap on plugs is .032 and were changed a few days before the tune. Trans is stock and the tc is a custom build I will post a picture of the best pull we got when I get home. And the boost kept at 10psi the entire run. If I'm not mistaken the 60 should be good for 600hp. But I am outside of the center graph for the turbo. Is there a way to test the tc to see if it's slipping?
Old 08-02-2009, 03:20 PM
Naw the 60-1 from sts is not going to net you 600 hp to the`wheels. If power is good down low and not up top then the turbo is out of breath the graph will tell it all. If the TC is slipping it will unload the turbo and boost will fall down as well as speed and you would smell it in a heart beat.
Old 08-02-2009, 09:20 PM
O1ws6's Avatar
Old 08-03-2009, 07:37 PM
Yeah that turbo is done its not going to do better after 5.5krpm Your numbers are not that bad for a stock motor and a stall how big is the stall? If you do the drive train power loss your near 500+ at the crank wich is border line for that turbo. You can make that same amount of power with less boost with a mpt 70 if not more Iats will be down also. that mpt70 will cost you bout 5-600 dollars and can support 600 hp. But im couriois on the rest of the set up. and why it took 4.5k rpm to hit boost.
Quick Reply: Question about power drop off
