Where to start with suspension
Mods: Pt4400, headers, ls6 intake, p&p throttle body, no front sway bar 15" wheels with 26x10.5 mt ET streets at 14-15lbs. Best I can 60' is 1.69 letting it hit 2nd gear and driving away as far as I can during the burnout.
It doesnt blow the tires off but it chatters/vibrates/wheel hops however you want to describe it. Theres no point to add any more power untill I can dead hook what I have. I am on completely stock suspension, where do I start? I am thinking I need more weight transfer. Theres no reason these tires shouldnt hook up.
drag bags are cheap and can help a lot depending on the car.. all you need is one on the rear right..
LCAs, TQ arm would be my starting point.. if that hooks you thn run that until your making enough power and start spinning again.. then look into more things.. rear sway bar etc...
Go adjustable. All you have to do is adjust it right the first time and your done with it. Shocks/Springs, LCA's, Panhard, Torque Arm, etc. BE SURE TO HAVE EVERYTHING SQUARED OFF! That's a big mistake lots of people make when bolting on suspension, they just slap the **** on there and call it a day. WRONG.... My grandpa and I are also going to try a whole different set-up as far as the rear sway bar is made. More of like an Anti Roll thing that we put on the "Super Outlaw" cars run. I'll post pictures of it when it's built and done.
