No driver side cooling fan
Old 08-04-2009, 03:08 PM
Detroitmuscle's Avatar
Default No driver side cooling fan
After reassembeling my car and getting it retuned we noticed that the driver side cooling fan won't turn on at all. its plugged in and all my grounds are good, all my other electrical works just fine. The fan comes on when you hardwire it up so I know the motor works and I replaced all of the relays with no luck. The temp sensor works just fine so I know thats not the problem. The pass side fan works fine on low and high. The car actually doesn't get very hot but if I sit in traffic for a while only the pass side is helping to keep it cool. Do you guys have any ideas?
Old 08-04-2009, 03:10 PM
SparkyJJO's Avatar
Correct me if I'm wrong but doesn't the one fan only come on when it gets really warm?
Old 08-04-2009, 06:00 PM
Lt14mla's Avatar
have you checked the fuse box. i think there's relays for each fan.
Old 08-04-2009, 08:34 PM
both fans run whether its on high or low and I mentioned that I have replaced all the relays.
Old 08-04-2009, 09:09 PM
Lt14mla's Avatar
interested in seeing responses to this.
Old 08-05-2009, 12:43 PM
Me Too! both fans are set to come on at 180 and only one is
Old 08-17-2009, 09:44 PM
bump... I turn on my a/c and the pass side comes on immediately but nothing happening on the driver side yet.
Old 08-17-2009, 09:46 PM
SparkyJJO's Avatar
Use a meter and start checking wiring. See if the relay is getting the signal to turn on for example.
