best cam swap method
Old 08-04-2009, 03:37 PM
formerly twolow02fransen (2014-1-2)
02_Orange_D1SC's Avatar
Default best cam swap method
well im doing a cam swap very soon just wondering what you guys think is the best way to hold the lifters up as i pull out the cam
1. russian rullet dont use anything just spin the cam till the lifters stay in the trays
2. pen magnets to hold up the lifters
3. the JPR tools from thunder racing which i heard you can use some 5/16 wooden dowel also
im probably going to use three
Old 08-04-2009, 04:14 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Wooden 5/16" dowels!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-04-2009, 04:16 PM
TXsilverado's Avatar
yep.
ive always taken my chances and did the russian roulette game. never had a problem on my high mileage motor.
Old 08-04-2009, 07:09 PM
eseibel67's Avatar
They stick up pretty good with the Russian Roulette method.
But I say shell out the $1.50 for the dowels. They allow you to sneeze during the install if you have to.
Old 08-04-2009, 07:45 PM
how long do they have to be?
Old 08-04-2009, 09:45 PM
Brandon35thSS's Avatar
+1 for the wooden dowels. i slid mine in till they hit the back and sawed off the rest leaving enough to pull them back out and it worked as good as the expensive jpr tool for me.
Old 08-04-2009, 09:47 PM
eseibel67's Avatar
Just checked the ones in the garage I used - they are 24" each.
I think they stuck out a bit, but they worked great.
Old 08-04-2009, 09:50 PM
ttranssam's Avatar
or my method...put heads on too...lol ya befor i got my heads i had heard the dowl rod thing is safe fast
Old 08-04-2009, 09:53 PM
My95Z's Avatar
Just rotate and go! Thats the way I've done it and never had problems although it might be worth the piece of mind to use the dowels.
Old 08-04-2009, 11:25 PM
ok so atleast 24 inchs each ill have to go to home cheapo and see what they got
Old 08-04-2009, 11:28 PM
wish i had the money for heads but not now that will come later
Old 08-05-2009, 09:29 PM
eallanboggs's Avatar
Steel dowels cost just slightly more than wood and don't get stuck in the block. Apparently you haven't read the horror stories on the site about what happens when a wooden dowel gets stuck in the block. If you are high mileage I'd shy away from the Russian Roulette method. Actually I shy away from it either way considering the extra cost, time and work if a lifter drops. This method is supposed to be a time saver, but if a lifter drops you'll be wasting plenty of it. I don't like taking those kind of changes. When I feel lucky I play the Powerball not Russian Roulette.
Old 08-06-2009, 08:52 PM
crossroads's Avatar
^^^ i went to lowes...got two 5/16 metal dowels and ground each one down on one side to make it mimic the ones that thunder racing sells....worked perfect for ten bucks
Old 08-06-2009, 08:57 PM
GT Griller's Avatar
LS1Tech 10 Year
Done all 3 and the dowels by far are the easiest.
Old 08-06-2009, 09:43 PM
Chrome355z's Avatar
I just got brake line and beat one side lightly with a hammer, worked fine for me...
Old 09-06-2009, 02:58 PM
Kurtomac's Avatar
where do these dowels go? is it behind the retainer plate the 2 oiling looking holes?
Old 09-06-2009, 09:08 PM
RARON455's Avatar
If you have a lifter drop on you, you will never forgive yourself for not spending a few extra dollars and minutes.....if you think changing the cam is fun, You will love getting a little bit of the oil pan and gasket
and yes from my understanding the dowel rods go here, see pic
