Western Members CA, AZ, NV, UT, CO, NM, HI
Need a 9" center section or a 10 bolt
Old 08-05-2009, 05:20 PM
Jimmard's Avatar
LS1Tech 10 Year
Default Need a 9" center section or a 10 bolt
I'm trying to locate a vibration I picked up when I put my moser 9" in. If anyone has an extra 9" center section that takes 31 spline axles, I'd like to swap it with my center section just to see if the vibration goes away, wouldn't even leave the driveway. Also if anyone has an extra 10 bolt laying around I'd like to swap my rear out just to test that also. I wouldnt even be leaving the driveway, so I'd only need to borrow them for the weekend. Will come pick them up of course. Somebody help me out!
Old 08-05-2009, 05:36 PM
geovett's Avatar
I have a 10bolt u can borrow....send pm...
Old 08-05-2009, 05:46 PM
Jimmard's Avatar
LS1Tech 10 Year
Ok I've got a 10 bolt, anyone have a 9" center section for 31 spline axles?
Old 08-05-2009, 09:32 PM
Wicked94Z's Avatar
why do you think its from the rearend?
Old 08-05-2009, 11:02 PM
Jimmard's Avatar
LS1Tech 10 Year
I dont know what its from, trying to eliminate things and next in line is the rear axle.
Old 08-06-2009, 09:36 AM
tripblackls1's Avatar
check you axles themselves i have had a problem with one of my moser axle not being strait and giving my mad vibrations
Old 08-06-2009, 02:59 PM
Jimmard's Avatar
LS1Tech 10 Year
I pulled the axles and had them checked for straightness, they checked out good.
Old 08-06-2009, 07:38 PM
Wicked94Z's Avatar
not a ds problem?
Old 08-06-2009, 07:44 PM
Jimmard's Avatar
LS1Tech 10 Year
brand new PST 3.5" aluminum driveshaft, had the stock driveshaft in there first and it does it the same with both driveshafts
Old 08-07-2009, 02:04 AM
Wicked94Z's Avatar
hows the ds length? mine vibrated crazy above 55 because the shaft was 1" too short
Old 08-07-2009, 02:10 AM
Jimmard's Avatar
LS1Tech 10 Year
I have adjustable control arms, so I pulled the rear end closer to the transmission to make up for it being a little too short. I have about 1" of the driveshaft showing out of the back of the transmission, so I have that covered too . Like I said I've already gone through everything haha.
Old 08-07-2009, 02:21 AM
Wicked94Z's Avatar
if thats the case your ds is definitely too short and it is causing vibration. didnt you order the pst shaft for your 9"? EPP sent me a stock length shaft, i had to pay for shipping back, but they sent me a 1" longer shaft the next week.
Old 08-07-2009, 02:23 AM
Jimmard's Avatar
LS1Tech 10 Year
By moving the rear axle forward 1" it made the driveshaft the perfect length. Unless moving the rear axle forward for some reason would cause a vibration that I am unaware of?
Old 08-07-2009, 02:24 AM
Wicked94Z's Avatar
im on my phone so i cant see your location. but what kinda yoke is on your 9"? if you're not real far from 91784 you could give my pst shaft a shot.
Old 08-07-2009, 02:25 AM
Jimmard's Avatar
LS1Tech 10 Year
Its for an M6, but it has a viper tailshaft upgrade. I am in santa clarita, near magic mountain.
Old 08-07-2009, 02:26 AM
Wicked94Z's Avatar
if 1" is showing out of the tailhousing its too short, it should have a max of 1/4"
Old 08-07-2009, 02:33 AM
Jimmard's Avatar
LS1Tech 10 Year
Well I bought the driveshaft about a year and a half ago so I think it may be a little late to ship it back to EPP for a swap haha.
Old 08-07-2009, 02:50 AM
Wicked94Z's Avatar
give it a shot, mine was about a year since i was in iraq and they asked no questions, i didnt have an invoice, order number anything. bc i swore at the time they told me a moser 9" takes a stock length shaft. mine ended up a little more that 1" longer bc i have 28" tires and had to move the rearend back to clear the front of the wheelwell.
Old 08-07-2009, 02:51 AM
Jimmard's Avatar
LS1Tech 10 Year
Hm interesting, I will give them a call tomorrow because the last possible thing I could check was the driveshaft. Thanks for the advice.
Quick Reply: Need a 9" center section or a 10 bolt
