Are 2 series carrier 3.73s worth it????
Old 08-05-2009, 07:20 PM
98z28jorge's Avatar
Default Are 2 series carrier 3.73s worth it????
my question is if the 2 series carrier 3.73 gears worth the money and time or will they break or suck my car has 2.73s so i have the 2 series carrier and dont have the money to change the carrier thanks in advance
Old 08-05-2009, 07:35 PM
key4's Avatar
I think with the 2 series carrier the ring gear is thicker than the 3 series. I got a buddy that is cutting any where from 1.56 to 1.62 60 foots with his 3:73 2 series. So you should be fine
Old 08-05-2009, 07:38 PM
98z28jorge's Avatar
hey thanks so hopefully they'll work did he have any problems with noise or the install?
Old 08-05-2009, 09:08 PM
key4's Avatar
No problems with the install and no noise when I rode in it. He bought the summit gears also
Old 08-05-2009, 09:38 PM
gold98Z28's Avatar
the thick gears are strong, and set up is the same as any other gear.
Old 08-05-2009, 10:15 PM
BADBOYZ28's Avatar
I ran a 2 series carrier with 3.42's. I cut mid 1.3 60ft. for a while but after every pass it got louder & louder until it finally gave.
Old 08-06-2009, 08:36 AM
Tommyv8's Avatar
So even with the same ratio, the gears in a 2 series carrier will be thicker and stronger than those in a 3 series? I have a 2 series and was thinking about getting a 3 series but maybe not any more.
Old 08-06-2009, 12:30 PM
gold98Z28's Avatar
yes the two series gears that are lower ratio are a "thick" gear. the carier is offset more so it requires a spacer for a 3 series gear or the specific thick gear. ive ran 3.73 and 4.10 without issue for years
Old 08-06-2009, 05:09 PM
99corvette's Avatar
i just put 3 series gears in my 2 series carrier on accident
Old 08-06-2009, 05:54 PM
gold98Z28's Avatar
didnt turn out too good did it. lol since you already have gears it would be cheaper for you to just get the spacer to put behind the ring gear
Old 08-06-2009, 06:22 PM
99corvette's Avatar
no so far its fine. the ring gear isnt off. its just the pinion gear was 20 thousands to deep without any shims
Old 08-06-2009, 06:50 PM
99corvette's Avatar
im really confused about this.
Quick Reply: Are 2 series carrier 3.73s worth it????
