engine wont idle, or stay running
well to start off my engine will start and then usualy idle high for mabey 10-20 sec and then shut off. Ive tried messing with the timimg and carb a bunchhh and nothing seems to help...any ideas??
heres the set up:
355 w/flat tops, 64cc/197 al. heads w/ 1.5 rollers, air gap intake, 750 speed demon carb, and comp cams 282 hyd. roller .510/.520 lift, 282/288 duration230/236 duration @ 50
thanks for any help!
-andy
heres the set up:
-andy
yes i tried holding the gas at about 3000 and it still cut off, just like i turn the key off, and even if i pump the gas its like im not even doing it cause it still shuts right off
the motor is in a 91 c1500 short bed single cab
yes it was tbi originally, but i had already had a carb motor in it before this engine...and everything worked fine, i do have an HEI hooked up to a msd 6al box
as far as i know i hooked up everything how it was before, i duno its frustrating lol i just wana drive it!
arite ill deff give that a shot thanks
also there is 3 wires that plug in to the dist. cap...if they are wired wrong(which i dont think they are) could that mabey cause this?...one is a ground but im pretty sure its grounded good
In an HEI cap, theres a 12V hot wire, a ground wire, and a tach wire. Colors should be red,black and white for the tach I believe.
The way its cutting off clean, its something electrical.
Wheres the 6A box getting power from? It should have 2 red wires, one big one for straight to the positive side of the battery or the starter itself where the battery cable is and also one for switched 12V...which means getting power only when the key is on.
yes its connected to the battery....mabey a wire has come loose that i have not seen
would the motor still start if it was not hooked up? or would it just not spark at all and just crank?
ok well ive answered my own question, i just unpluged the three wires and it did not spark at all and didnt start. so now i guess ill get a buddy and have him hold a test light while its running and see what happens from there. if it still does have power when the engine shuts off, what should i look for next?
Carb gasket? Intake gaskets? An open vacuum port on the intake, like going to a brake booster? Get some soapy water (with visible foam) and a spray bottle and start spraying the obvious places like this. It should be easy to see it get sucked in if that's the problem.
Have you had the heads milled? If so, did you get the intake flanges milled also? If the heads are milled and you didn't do this, bet that's your problem.
all gaskets are new...i have the brake booster connected to the carb, thats how i had it before when i had a vortec setup.....and if u pull the tube outa the brake booster u can hear air like theres vacuum....could theyre be a spot in the non vortec manifold that you can plug a vacuum hose into that is mabey just open right now?
ya i guess thats true...also if there is a hole on the intake for that then i dont think its plugged so maybe thats the problem...i sure hope its something easy like that
ya the booster is ok, however it is old. but there was an open port in the intake and i plugged that off and did some carb adjusting, and i got it to idle. but its still weird...sometimes itll start right up, sometimes it wont, but it stays at idle for a min or so now and then kind of sputters off....maybe a fuel problem?
