ls1 or ls6 block on 02 ss
Old 08-08-2009, 12:28 AM
mastercoryd's Avatar
Default ls1 or ls6 block on 02 ss
tried searching but couldnt find it just looking for a quick answer... where to i search to see if my block is an ls6 or ls1 block i know theres not much of a difference but j/w i have an 02 ss and i know half of the 02's come with ls6 blocks and i was j/c thanks
Old 08-08-2009, 12:58 AM
94lt1m6's Avatar
25% in 02 came with the LS6 block. You have to use a mirror, and look on the drivers side rear deck just below the head. I don't know the full # but the first four for an LS6 are 1256 and LS1 are 1255.
BTW I looked for hours for that sticky the other day and couldn't find it...
Did find out mine is an LS6
Old 08-08-2009, 12:17 PM
pcs9449's Avatar
Just look for the bullseye on the water pump pad on the passenger side of the block, if it has it, it is LS1, if it doesn't, it is an LS6 block.
Old 08-08-2009, 12:30 PM
02*C5's Avatar
I think what you are talking about is either a 5.7 or a 6.0 block. What made the LS6 different from the LS1 was the cam, lifters, heads and intake manifold. The LS6 was and LS1 with a different upper end and after 2002 the intake manifold was the same.
Old 08-08-2009, 12:33 PM
kinglt-1's Avatar
LS1Tech 10 Year
Could you explain, I cant find a bullseye? Im trying to figure out the same thing the op is lol.
novaflash2002's Avatar
the ls6 block is built a little beefier
Old 08-08-2009, 12:54 PM
2001SS_stompinsupras's Avatar
01' and later LS1 and LS6 blocks are for the most part identical. Pre 01' blocks are less desirable because of crankcase pressure problems.
Old 08-08-2009, 04:06 PM
pcs9449's Avatar
I couldn't get very good pics, but this will give an idea, the bullseye is LS1 block, the non-bullseye is LS6 block.
Attached Thumbnails ls1 or ls6 block on 02 ss-dsc01685.jpg   ls1 or ls6 block on 02 ss-dsc01686.jpg   ls1 or ls6 block on 02 ss-dsc01687.jpg
Old 08-09-2009, 01:41 PM
VincesSS's Avatar
http://www.idavette.net/hib/ls6/page3.htm
Found lots of awesome info here with a brief google search.
Quick Reply: ls1 or ls6 block on 02 ss
