5th & 6th gear issues
Old 08-09-2009, 05:10 PM
passnu2's Avatar
Default 5th & 6th gear issues
Driving my '02 SS today lost 6th gear & it is trying to kick out of fifth under throttle. If I back completely out of it it falls into neutral. It grinds a little as I stick it back into gear. If I try to go to sixth its like there is nothing there. You can barely feel the teeth making contact.
Old 08-09-2009, 05:57 PM
thesource's Avatar
Very possible that you stripped the mainshaft and matching 5-6 cluster gear.
Old 08-09-2009, 06:44 PM
dlc1609's Avatar
Sounds like it....I just did that to mine! =)
Old 08-10-2009, 08:24 PM
passnu2's Avatar
What would cause that to happen? :o
Old 08-10-2009, 09:53 PM
thesource's Avatar
Usually high milage.
Old 08-11-2009, 09:41 AM
bearcatt's Avatar
Best to get that fixed asap before it causes more damage.
Old 08-12-2009, 04:18 PM
passnu2's Avatar
It's an '02 with only 34k on it. I wouldn't call that high milage and it's only putting a little over 400 to the tires.
Old 08-12-2009, 04:33 PM
thesource's Avatar
Thats not enough miles to strip the mainshaft or 5-6 cluster gear.
Old 08-12-2009, 04:38 PM
thesource's Avatar
I'm going to say its a 5-6 shift fork related issue. Do you happen to leave your hand on the shifter while cruising down the highway?
Old 08-12-2009, 06:56 PM
passnu2's Avatar
most of the time.
Old 08-13-2009, 09:09 AM
thesource's Avatar
Stop doing that. You probably wore out the fork for the 5-6 gears.
Old 08-13-2009, 08:20 PM
passnu2's Avatar
I drove my '97 SS the same way for 123k and never had a problem out of it. That car was drove hard and put up wet. In my opinion they screwed up when they changed the way the t56 was built.
Old 08-16-2009, 11:15 AM
passnu2's Avatar
Dropped tranny yesterday and it looks like a broken snap ring and some busted up detents. I'll find out more when it gets torn all the way down.
Old 08-16-2009, 11:57 AM
thesource's Avatar
Thats not too common to break the snap ring like that.
Quick Reply: 5th & 6th gear issues
