'00 S10 4.8 Dyno Results
Old 08-13-2009, 12:12 AM
CODE4LS1's Avatar
Default '00 S10 4.8 Dyno Results
Ok here it is:
Stock 4.8 w/Sanderson shorties, 2.5" y-pipe to 3" cat and pipe through a Dynamax muffler. Built 4L60E and built rear w/3.42 and eaton posi.
97* out and no humidity.
Dynoed on a Dynomax loaded dyno (similar to mustang dyno).
Numbers are:
Tuned by Ryne at CMS in Lake Elsinore.
A/F ratio:
I personally think it's not that bad for the smallest genIII LS motor and 140*+ IAT's (nothing I can do about the IAT's either).
So lets hear what everyone else thinks!
Old 08-16-2009, 12:44 PM
JonCR96Z's Avatar
Not bad at all. What year is the 4.8?
Old 08-16-2009, 01:38 PM
NemeSS's Avatar
not bad atoll! thats around 315-320bhp
mill the heads, thinner gasket, LPE GT11 cam or 02 z06
and will pump out some more hp
Old 08-16-2009, 05:37 PM
CODE4LS1's Avatar
Motor is from a '03 Silverado
I will be looking into '03 ZO6/243 heads, cam and springs.
Already freakin bored with the power level and it hasn't been a week!!
Old 08-16-2009, 05:48 PM
Petraszewsky's Avatar
Haha...Like most everyone else on here and s10forum....building something new and instantly bored with it...
Old 08-16-2009, 06:03 PM
96lt1m6's Avatar
The advantage in being bored with these motors you add some boost and the affair continues to grow....MP-70 would put a smile on
Old 08-17-2009, 03:17 PM
NemeSS's Avatar
or could go with regualr 799 heads which are same design as 243, but with reg. valves. and cheeper
Old 08-17-2009, 03:37 PM
JonCR96Z's Avatar
I'd go with something a little bigger on the cam. Your best bet would be a nice turbo setup, then maybe I could see the LS6 cam.
Old 08-18-2009, 01:03 AM
CODE4LS1's Avatar
I didnt know that, thanks man!
Old 08-18-2009, 01:05 AM
CODE4LS1's Avatar
Nah, I want to keep it fairly mild as it's my DD work truck, the big power parts will be used on my C5
I know other cams will pass smog also, but you cant beat LS6 cam and springs!
Old 08-18-2009, 06:12 AM
hotrodscrap's Avatar
Nice, did you have a build thread on on of the truck forums?
-SS
Old 08-18-2009, 10:46 AM
CODE4LS1's Avatar
-SS
Yeah I posted my build on a couple forums.
S10forum and Performancetrucks section here.
Old 08-18-2009, 11:20 AM
NemeSS's Avatar
243/799 are the same design. same thing as ls2 heads
real ls6 heads have the lite sodium filled valves.
Old 08-18-2009, 11:21 AM
NemeSS's Avatar
i have low miles set of 799 if your looking
Old 08-18-2009, 11:26 AM
The 243 heads that came off the Vettes had lightweight valves also...but the ones from the GTOs did not....
Old 08-18-2009, 11:32 AM
JonCR96Z's Avatar
LS6 heads had those valves not all Vette 243s.
Old 08-18-2009, 02:07 PM
LS1Tech Sponsor
hellbents10's Avatar
Very nice, like said above it would be cool with milled 799's and a ls6 cam!
Old 08-18-2009, 09:09 PM
cam75w/ls1's Avatar
I've always thought about a 4.8 swap in something cause of the rev potential from the short stroke.
Old 08-19-2009, 10:19 AM
CODE4LS1's Avatar
Originally Posted by cam75w/ls1
i've always thought about a 4.8 swap in something cause of the rev potential from the short stroke.
exactly
Old 08-19-2009, 10:29 AM
the_merv's Avatar
LS1Tech 10 Year
Nice..
Quick Reply: '00 S10 4.8 Dyno Results
