Anyone Running a Super Shield?
I have one.
I ran into a fitment issue right away with this shield. Supposedly, from my phone call to CSR, they had a bad batch of shields from the factory. My right most bolt hole did not line up. I had to pull out the aluminum sleeve and grind it to fit. I haven't got it into the car yet but should be this week. Everything I've read has said it fits with no modification.
~Jim~
~Jim~
I have one on a 350 it fits fine but you have to put the motor/trans in as a unit. unless you lower the K to get the bolts out cause they are so long. Or you could cut hole in the tunnel I guess
