LS1 ARP head studs
LS1 ARP head studs
Hi all
I have an ls1 that i am building with a set of Dart Pro heads.The block is a brand new crate block. I am having problems with a set of head studs i got as they were the wrong ones.
What's wrong is that the threads in the block are different lengths from the top ones to the bottem ones.
Can someone please help me with getting the right length studs?
Thanks, Daniel
Thanks, Daniel
I'm not sure if this affects you or not... but I'll be buying ARP head bolts for my car soon, and noticed that there is a different part number for 2004+ blocks.
So maybe you have the wrong part number?
Mine says E274 which means May 27 2004 so I have the new style that uses all the same bolts.
