torque management and drive by wire help
Old 11-24-2003, 10:47 PM
single digit dreamer
parish8's Avatar
Default torque management and drive by wire help
GRRRRRRR, this isn't working well. i have serious TM, i went thru the steps and still have it bad, expecialy the closing throttle blade at the shift.
here is what i did.
1. Transmission -> A4 Shift Firmness -> Torque Reduction...Fill the whole table with zero's
2. Trans Calibration -> A4 Shift Firmness -> Upshift Torque Reduction...Fill the whole table with zero's
3. Engine -> Ignition -> Max Torque...Set it to 639,
4. Engine -> Ignition -> Torque Reduction...Fill the whole table with zero's
and it didn't seem to make any diference, this things falls on it's face HARD at the shift. here is a section of atap, remember i had it floored the whole time.
Old 11-25-2003, 06:08 AM
LS1Tech Sponsor
Slowhawk's Avatar
You need to shorten the shift speed,raise line pressure,and maybe set shift point earlier.
Old 11-25-2003, 02:02 PM
parish8's Avatar
ok, but how do i keep the timing from going negative and the throttle from closing?
Old 11-25-2003, 02:18 PM
LS1Tech Sponsor
Slowhawk's Avatar
I think the negative timing is a misread from your scanner.
Does your truck have an electronic throttle?(no cable)
I would just guess the tranny is lazy at shifting.
Did you install a shift kit with the converter?
Old 11-25-2003, 04:44 PM
parish8's Avatar
i get the negative timing every time i shift at WOT, it is very repeatable and yes i do have drive by wire(no cable)
Old 11-25-2003, 05:42 PM
LS1Tech Sponsor
Slowhawk's Avatar
HMMM,It's a new one to me.Haven't worked on a truck,by wire setup before.
Old 11-27-2003, 04:20 PM
Reboot's Avatar
Are your values negative in the spark retard limit table? If you change them to a positive value of say 15 you will get 15 degrees of timing during a WOT shift.
Old 07-20-2005, 09:45 PM
what a rush!
moregrip's Avatar
you ever figure this out P?
Old 07-20-2005, 10:19 PM
parish8's Avatar
yeah, most of the problem was in the ETC(electronic throttle control) tables. i thought that was traction control so didn't really mess with it. i have ran into some other problems along the way too but was able to program them out too.
Old 07-21-2005, 12:20 AM
SmokingWS6's Avatar
I really need to read the dates on post. lol I'm sitting here going how the **** does he not know about the etc tables. lol. oh well, just show's we all had to learn the basics too.
Old 07-21-2005, 04:39 PM
what a rush!
moregrip's Avatar
ahhh, I see, can you help me out here?
in this table, should all values be 100?
Old 07-21-2005, 10:02 PM
parish8's Avatar
my table still looks like that. at the time is was just the "ETC controled rpm limit", i was bumping the limiter.
Old 07-21-2005, 10:24 PM
StealthV's Avatar
Making that table's values all equal to 100 will completely eliminate traction control even if it were "on". Once one switches T/C off, the table is ignored.
Old 07-22-2005, 12:28 AM
SmokingWS6's Avatar
don't bump all tables to 100%, you want it all Zero'ed out if you dont want etc limitation.
Old 07-28-2006, 12:38 AM
playtoy_18's Avatar
HAHA,Reviving the old thread once again
I am working on a 8.1L ETC truck.Just clarifying that all zero's will effectively rid the ETC Torque Management.
Quick Reply: torque management and drive by wire help
