Drag Racing Tech
whats a good tire pressure
Old 08-24-2009, 09:02 PM
Smoke Em's Avatar
Default whats a good tire pressure
whats is a good tire pressure for 285/40/17 nittos nt555's, the street tire
mods in sig stock lt1
for drag racing ??
Old 08-27-2009, 09:56 PM
Smoke Em's Avatar
i know im not the only person running these tires at the track
someone anyone ??
Old 08-27-2009, 10:20 PM
transamsam98's Avatar
this can very so much that the best anyone will be able to give is a ballpark range but i agree someone must have an idea
Old 08-27-2009, 10:46 PM
Gen414's Avatar
Low profile tire like that, start @ 25 PSI, and work your way up/down from there. Probaly will need to go up, but every car is gonna be different, especially *** end weight.
What you can do is drop your tires to @ 25 PSI, and do a pretty good burnout, right there in your driveway or what have you, and soon as you finish, hop out as quick as you can if you don't have a friend with you (which obviously helps if you do), and feel the tire. Looking for the tire to be hot across the WHOLE tire.
If TOO much pressure, it will be more so in teh center (tire will "bow"), and if not enough, it will be hotter @ the outer edges. (tire will "cup").
AND, if you are fortunate enough, you can actually LOOK at the tire marks on teh ground. If it is blacker on teh outer edges, not enough pressure. If darker in center, too much. Uniform across whole tire, perfect.
Old 08-29-2009, 04:43 PM
Kent1's Avatar
for nitto's 14 to 19 psi
drags or slicks 14 to 18 I run mine most of the time at 14
Old 08-29-2009, 10:42 PM
jsafe's Avatar
I run 20 in mine. works good [22 on motor]
Old 08-30-2009, 12:48 AM
TORCHD 02 TA's Avatar
on my nitto 555 EXTREMES 315/35 i put them down to 25 psi and got me a 1.9 60'
Old 08-30-2009, 12:57 AM
Not to hijack from the OP..
GEN414 what tire pressure do you recommend for M/T ET Street DRs 26X10.5X16???
Old 08-30-2009, 03:03 PM
Smoke Em's Avatar
hey torchd was that 1.9 pretty much stock
Old 08-30-2009, 03:38 PM
What do you mean stock? Was my car stock? No, I am cam only and at the time ran a 12.3 @ 115 with the 1.9 60 on the nitto street tires
Old 08-30-2009, 04:56 PM
Smoke Em's Avatar
ok i was stock and pulled a 2.0 on goodyear 245s so im hoping these will help my 60 ft
Old 08-30-2009, 07:05 PM
Gen414's Avatar
Tire like that, with more sidewall than teh above mentioned tire, down to @ 14-16PSI, and same thing, go up/down as needed.
You want to run AS MUCH tire pressure that you can, and STILL hook...remember that.
Old 09-01-2009, 11:41 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
That is the key! Less rolling resistance, better times. Sometimes when you spin, people assume to drop the pressure. You may already be too low and cupping a radial tire (not the same as a slick), so sometimes making 2 or more runs at a certain pressure is needed to verify the results (not being in the groove, too small or too big burnout, etc).
Derek
Old 09-01-2009, 02:07 PM
9sec93's Avatar
tire pressure regardless of size and type of tire depends on vehicle weight, how much power you are making and how well your suspension is working.
Old 09-01-2009, 07:42 PM
Smoke Em's Avatar
stock 95 lt1 17" 10 spokes, stock weight with stock suspension
Old 09-01-2009, 09:17 PM
Randy WS6's Avatar
When i run Nitto's, i run 22 psi.
Old 05-30-2012, 09:53 AM
HibachiZ28's Avatar
I'll be testing some of these theories tonight lol.
Old 05-30-2012, 09:58 AM
baalic's Avatar
I ran those exact tires at the track. I had them around 18 psi, 2k launch and bogged... So I say 18 psi with a 3k drop... 2.1 60' stock ws6
Quick Reply: whats a good tire pressure
