Which valve springs for stock engine with 6-8psi of boost?
Old 08-26-2009, 01:18 PM
Monello's Avatar
Default Which valve springs for stock engine with 6-8psi of boost?
Think im getting some valve float or maybe have a broken spring. So I have a good excuse to swap them out.
Old 08-26-2009, 01:38 PM
NemeSS's Avatar
cc 918, can reuse all oe hardware, locks,ret. etc.
or really low budget, a set of ls2/ls6 spec.
Old 08-26-2009, 02:07 PM
RooRnZ28's Avatar
i've had patriot gold duals for 3 years now with 5-8 psi
Old 08-26-2009, 02:10 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Stock cam? If you want an upgrade, I'd just run the PAC1218:
http://www.sdparts.com/product/PAC12...veSprings.aspx
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-26-2009, 02:28 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
We really need to know more about the combo! What head is it (or more importantly what valve in the heads)? What are the cam specs?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-26-2009, 02:48 PM
Customizing Director
MadIceV8's Avatar
I plan to run patriot gold duals. But I'm also going to be cammed with a 588/595 lift.
Old 08-26-2009, 03:20 PM
Monello's Avatar
The motor is completely stock. Stock heads/cam I do have a set of 317 heads/ls6 cam that I plan on adding over winter.
So which spring will work for my current setup, and will also work with the future setup 317 heads/ls6 cam?
Old 08-26-2009, 03:30 PM
OUTLAWZ RACING's Avatar
Prc duals or patriot golds would do you just fine. Ive been on the same ones for awhile now598/608 lift cam in the 230 range
Old 08-26-2009, 03:57 PM
Duals of any sort would be overkill on a stock or LS6 cam. PAC 1218 or equivalent would be my recommendation. You could use LS6 springs for a cheaper alternative, but I personally would go with the PAC1218 or Comp 918. Any of them will use your stock retainers and locks.
__________________
Old 08-26-2009, 03:59 PM
Monello's Avatar
So these (PAC1218) will be perfectly fine with 6-8psi of boost? If so I will be ordering them shortly.
Old 08-26-2009, 04:17 PM
In my opinion, I don't see why that boost level would be a problem at all.
__________________
Quick Reply: Which valve springs for stock engine with 6-8psi of boost?
