tach wire
tach wire
im having trouble making my zex window switch work.. im on connector 2 pin 10 the white wire of the pcm. just wanted to check that i have the right wire
There should be two pure white wires on that connector. It is one of those but I am not 100% sure which one without looking at it. If you can wait until later tonight I can take a look.
the only reason i was wondering this is because on the zex window switch you have to set what kind of ignition coil set up u have and the only way it would read the right rpm is if i set it up for 4 coils. so i was sure if one white wire feeds 4 coils and the other feeds 4 coils.
so its the white wire oposite the locking side of the connector?
