clutch ? on ls1
Old 08-27-2009, 10:43 PM
zeus01's Avatar
Default clutch ? on ls1
I lost my clutch again.I bought a used one from a guy.He told me if was out of a ls7.
I have a 01 Z28 with a t-56.
i lined it up with the flywheel when i got it home and the doll pins dont line up on the clutch.I called the guy back and he said get them pressed out of the flywheel" alot of people do it".After looking at the flywheel it seems to make sence but The pressure plate is deeper.
My ?'s
Will pressing the pins out **** me and send it outa wack?
Can I run a longer bolt with out screwing my self either?
Any suggestions gents would be greatly appreciated. Im im tired of jugglin this trans.
Christian
Old 08-27-2009, 10:55 PM
Gen414's Avatar
My ?'s
Christian
Yes, most people don't run teh dowel pins.
Not sure what you mean, "Pressure plate is deeper" though????
Not sure why you would need a longer bolt...what bolt are you talking about?
Old 08-27-2009, 10:56 PM
zeus01's Avatar
The pressure plate is thicker.
the ones that mout the clutch basket to the flywheel.6 of'em
Ill get pics if needed
Old 08-27-2009, 10:58 PM
SIC LSX's Avatar
ls7 clutch to ls2 flywheel i have had it for 40k miles i love it
Old 08-27-2009, 11:12 PM
Gen414's Avatar
No pic needed, just verification was all. Stock bolts will be fine though, even though it is always good to buy new when replacing clutch....
Old 08-27-2009, 11:21 PM
zeus01's Avatar
Heres the clutch.Sorry about the res.I just shot'em and put'em up.Is this a ls7 clutch
This is what im talking about.The plate doesnt sit right.There is space between the "basket" and the flywheel.These are the bolt from the bellhousing in.
The left one is my old bolts.They are to damn short to thread in.Can I run longer ones safley.
Old 08-28-2009, 12:20 AM
Gen414's Avatar
First things first...what is up with your "basket" (also known as teh Pressure Plate)??? From teh looks of teh picture you included, is not anywhere CLOSE to sitting flush.
Can you get some different angles of it?
have you tried fitting the PP (pressure plate) on the flywheel, WITHOUT teh disc sandwiched between? What happens then? There is no reason for the PP to sit that high off the flywheel...
Old 08-28-2009, 12:25 AM
zeus01's Avatar
I will get more pics up in the a few mins.
That was what i was concerned about.I have done 1 clutch prior to this(same car).It wasnt like that at all.I keep my old parts.the spec to the auto zone dont sit like this.
I thought maybee a diffrent style..................Dunno
was there a mistake in the sale
Old 08-28-2009, 02:48 AM
zeus01's Avatar
Sorry got caught on the phone for a while.
It looks like once the pins are removed WITHOUT the clutch plate it would sit flush.I do have a used spec stg 5 disc i could use but it was shot when my slave blew up and pissed fluid all over it.
do I get ahold of this cat i got it from and let him know there was a mix up,whatcha think?
Old 08-28-2009, 08:57 AM
Gen414's Avatar
That is weird, I will say that. Are you saying that in teh LAST pictures just then, that you have NO disc and teh dowel pins are removed? WTF????
Only explanation is it is floating in mid air.
Hate to do this, but can you get pics of the bottom pf teh PP? Disc? Flywheel? By themselves?
Having a hard time seeing what is going on, as I will also say that the image's are NOT very clear, and hard for me to see everything also, so....???
Old 08-28-2009, 01:12 PM
SIC LSX's Avatar
its not suppose to be on ls1 flywheel you need ls2 flywheel
Old 08-28-2009, 01:36 PM
zeus01's Avatar
thats nice.the guy i bought it from failed to mention that.whats that gonna cost?
is it worth it?
should i give it back to the cat?
Old 08-28-2009, 04:08 PM
SIC LSX's Avatar
i would say around $250 from sponsors on here. more info for ya
http://kb.ls1gto.com/KB/article.aspx?id=10039
http://www.byunspeed.com/product_inf...oducts_id=4671
http://www.sdparts.com/product/12571...2Flywheel.aspx
Old 08-28-2009, 04:12 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
You can not use that clutch with your flywheel, you have to get the LS2/7 style flywheel. The mounting points are raised.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-28-2009, 05:15 PM
zeus01's Avatar
I wouldnt have bought it if i wouldve known that.I asked for a clutch for a ls1.The guy told me thats what it was.I asked him if it came with the flywheel he said no.He told me mine would work fine.Im just gonna sellit back to him.I still need a clutch for CHEAP!
Old 08-28-2009, 06:58 PM
SIC LSX's Avatar
u cant find one cheaper then that. that can hold as much as it
Old 08-29-2009, 12:45 AM
zeus01's Avatar
what do u mean?
How good is this clutch?
Im broke and my car has been down for 4 years now.
Old 08-29-2009, 01:34 AM
twelver12's Avatar
well the clutch comes on a car with 505 factory ponies so yeah its a good clutch
i almost started crying when i read that your car has been down that long, what the hell have you been doing to yourself the last four years? sounds like a wierd case of self punishment
Old 08-29-2009, 03:41 AM
SIC LSX's Avatar
i have 413whp and i dont see how anyone can speed shift or dog a car as much as i do and its still good after 40k miles. No clutch can beat it for the $$$$$. Just so you know they are self adjusting! The clutch will engage right off the floor at 1st but it will works its way up to the top of the pedal as it breaks in
Old 08-29-2009, 03:42 AM
SIC LSX's Avatar
i know of a few c6 z06 with 550whp-600whp still on stock clutch with no problems
Quick Reply: clutch ? on ls1
