Zaino users I have a guestion?
Im a new user to the zaino products and have a question on what i bought. I did the process on my silver ss wash with dawn dry clay bar wash again, used swirl remover on my car and wiped off then i used zfx with z2 and waxed then z6 then wax then z6 then waxed and let sit all night and wiped off this morning and z6 my car again. Do i wax again after 24 hours and z6 one more time and when do i use z8 and z-cs (clear seal) or did i waste my money on those two products.
what do you mean by waxed? You don't put wax over zaino, that is a no no. What swirl remover did you use? You can realistically use the Z5 (swirl remover for darker cars) then ZFX/Z2 as many coats as you want as the ZFX allows you to do so.
The process should be with what you have.
Dawn
Clay
Dawn
ZFX/Z2 - usually 2 or 3 coats will do.
The Z6 you spray a bit on the applicator to keep it moist before you put the Z2 onto it.
Z8
If i were you I would get Z5, I know it's geared for a darker cars but it helps to fill small swirl marks.
Then you can do:
Dawn
Clay
Dawn
Z5/w Z6 on applicator
ZFX/Z2 with Z6 on Applicator - 2 or 3 coats.
Z8 once complete with everything.
I've never used Z-CS so I am not sure if you wasted your money or not.
Dawn
Clay
Dawn
Z8
Then you can do:
Dawn
Clay
Dawn
Dawn
Clay
Dawn
Z8
Then you can do:
Dawn
Clay
Dawn
Dawn
Clay
Dawn
Z8
Then you can do:
Dawn
Clay
Dawn
To be honest I'm not 100% sure but I would seal all the polish in there , so after the Z2 I would put the Z-CS. Then you can use the Z8 as your quick detailer ontop of the sealer.
Yeah they call zaino a polish but it's really a polymer sealent. Kind of confusing.
As for the correct order. SOM is correct. As for the clear sealent. Maybe you'll have better luck than I did but it streaked pretty bad on a black car. I now use that on our lighter vehicles and stick with Z-5 and Z-2. Once I get about 4 layers of Z-5 on my car I start with Z-2 if I have time and Z-8 after every other wash. Good luck.
