175 shot, upgrade pump & injectors?? Suggestions please.
I was planning on spraying a 200 shot but i've changed my mind with that, haha. I'm now planning on doing a 175 shot and i was curious if i would need to get a bigger pump and/or upgrade the injectors as well? What else should i look into if i'm missing anything?
I think you should be fine with stock injectors. I would get a pump for sure though. A walbro 255 would be just fine. If you can budget it grab some injectors, some 36# should set you for what ever you're looking to do. What plugs are you running?
Wet has nothing to do with injectors. The pump is pretty much a must. And for any real purpose it would be silly to put a motor at risk for 100$.
walbro 255 would cover your bases.
If your really going to spray a shot of this size on a stock bottom end, Get the safety items as well sir.
Fuel pressure switch WOT switch of course.
Window switch honestly wouldnt hurt. I have seen autos spin hard enough into a shift that they hit the limiter.
Plugs will definitly need to be in the 7-8 range. non-projected tip being better.
Best of luck...
Pill it till you kill it.
Best of luck...
Best of luck...
Best of luck...
You definitely need to go with at least some br7ef's on a shot that size. I personally wouldn't run a tr6 anything over a 100 shot.
converting to a plate shouldn't be a problem you just have to run your lines to the plate and remount the noids where they need to be.
And I'm pretty sure that the racetronic kit is just a Walboro 255 pump with everything you need to get it to work. If the ebay pump isnt name brand I wouldnt mess with it seeing that the TSP in tank kit with a Walboro only costs $139
Linkage:http://www.texas-speed.com/shop/item...d=225&catid=10
