Western Members CA, AZ, NV, UT, CO, NM, HI
Where does this go???
Old 08-30-2009, 08:46 PM
Stroker396@APF's Avatar
Default Where does this go???
So I was working under the drivers side dash and I hear this spring pop.
I have no idea where it came from as I did not see it and by the picture you can see it is clearly broken and Only have 2 of the 3 pieces.
I just hope that it is not critical.
Old 08-30-2009, 08:58 PM
WYATT318MOPAR's Avatar
I can't really tell how big it is from the pic but how about out of the latch in the glovebox, if not it almost looks like a door spring.
Old 08-30-2009, 09:28 PM
ZexGX's Avatar
Perhaps the gas pedal or brake return spring?
Old 08-30-2009, 10:05 PM
hlaalu's Avatar
Originally Posted by LS1powered09
Door Brackets $10 shipped
kind of looks like that spring
Old 08-30-2009, 11:03 PM
thebulgd's Avatar
looks like some kind of return spring. Start the car check your brakes and brake pedal, if that all works drive around and see if the gas pedal works, if it dont atleast you know the brakes work so you can stop. or maybe just check all that before you go driving, your choice.
Old 08-30-2009, 11:46 PM
haighter's Avatar
It looks to me to be the CLUTCH return spring. It like $36 I think to get a new one.
Old 08-30-2009, 11:47 PM
Well I drove the car and it seems fine. It is not the door spring that comresses like a valvespring, like these guys are saying it looks like it should go to the gas pedal as it had a limited range. Right now the only thing pulling the gas pedal back is the throttle body spring.
Old 08-31-2009, 12:39 AM
SUCK MY SS's Avatar
cj is right, its the return spring for the clutch pedal.
