2004 ctsv throttle pedal wire position.
I put a 2004 ctsv ls6 in my rx7 and I'm getting code p1125 and have to control of the throttle. I got a harness made for me that goes from the throttle pedal to the tac module. Two different wiring diagrams show the pins/colors of wire in different positions in the connector. I really, really need one of you guys to look down by your accelerator and write down the position and colors of the wires going into the connector on the pedal. Please!! Help!
Looking at my 05, don't know if it is the same or not, the wires are-
outside (closest to door) top to bottom- white, purple, light blue, tan, gray.
Inside (closest to console) top to bottom- green, yellow, none, light blue, blue.
I didn't get to look close enough for any trace colors, just crawling under the dash was ruining my buzz lol. If you need trace colors as well, let me know and I'll look tomorrow for you.
Accelerator Pedal Position (APP) Sensor
Connector Part Information
• 15326842
• 10-Way F 150 Series Sealed (BK)
Pin
Wire Color
Circuit No.
Function
A
GY
1273
Low Reference
B
PU
1272
Low Reference
C
L-BU
1162
APP Sensor 2 Signal
D
TN
1274
5-Volt Reference
E
YE/BK
1275
5-Volt Reference
F
D-BU
1161
APP Sensor 1 Signal
G
L-BU
1276
5-Volt Reference
H
Not Used
J
BN
1271
Low Reference
K
D-GN
1163
APP Sensor 3 Signal
• 15326842
Pin
Wire Color
Circuit No.
Function
A
GY
1273
Low Reference
B
PU
1272
Low Reference
C
L-BU
1162
APP Sensor 2 Signal
D
TN
1274
5-Volt Reference
E
YE/BK
1275
5-Volt Reference
F
D-BU
1161
APP Sensor 1 Signal
G
L-BU
1276
5-Volt Reference
H
Not Used
J
BN
1271
Low Reference
K
D-GN
1163
APP Sensor 3 Signal
• 15326842
Pin
Wire Color
Circuit No.
Function
A
GY
1273
Low Reference
B
PU
1272
Low Reference
C
L-BU
1162
APP Sensor 2 Signal
D
TN
1274
5-Volt Reference
E
YE/BK
1275
5-Volt Reference
F
D-BU
1161
APP Sensor 1 Signal
G
L-BU
1276
5-Volt Reference
H
Not Used
J
BN
1271
Low Reference
K
D-GN
1163
APP Sensor 3 Signal
• 15326842
Pin
Wire Color
Circuit No.
Function
A
GY
1273
Low Reference
B
PU
1272
Low Reference
C
L-BU
1162
APP Sensor 2 Signal
D
TN
1274
5-Volt Reference
E
YE/BK
1275
5-Volt Reference
F
D-BU
1161
APP Sensor 1 Signal
G
L-BU
1276
5-Volt Reference
H
Not Used
J
BN
1271
Low Reference
K
D-GN
1163
APP Sensor 3 Signal
Anybody with a '04?
here is the connector Attachment 195169
Thanks. I couldn't see them because they are so small. My connector matches the one in the pic. It still shows a wire going to a position without a pin on the pedal itself.
What position is empty on your connector?
The "H" cavity should be empty.
The chart that ctsv-ls6 supplied you with is the correct pinout for an 04 CTS-V APP sensor.
If the pedal doesn't match the pinout, check on the pedal asm for a part number stamped into it to verify its the correct part.
connector?
connector?
