For those of you who have UMI's Lower A-Arms...
Just wondering what your opinion of them are? I've got a set that I'm thinking about using. The factory arms look much stronger than do the aftermarket ones. I just want to hear if anyone has had any issues with them bending/cracking/breaking etc... Also, what kind of driving do you do with them?
Thanks!
Thanks!
I did bend the lower shock mount when I hit a pothole, UMI then quickly sent me a spacer to repair it. I just wish they would post those spacers for sale separately so I can buy some more and stack them to raise the ride height a bit. But with the spacer I can say it is bullet proof
Also, how was the alignment process with the aftermarket arms? Easier, more difficult? Any issues you ran into along the way while installing them?
Thanks
For adjusting you might not even have to touch them, especially if you are using our K-member. We recommend to set the A-Arms to factory length and use the K-member slots for adjustment... its the same as using the factory A-Arms and factory K-member... just more adjustment in the slots.
Thanks!
Ryan
Thanks for the post Ryan! I am going to go ahead and run the UMI arms. I've also got your K-member so that should make things easier. You will be sending me the bushing replacements in the mail so when I thread them in what is factory length? I remember being told once that it's 7/8" from the top thread below the bushing to the bottom of the jam nut? Is this correct for both the front and rear bushings?
Also, I potentially may be running an iron block in the future, I know the iron block is about 75lbs heavier, will this stress the arms in any way?
Thanks again Ryan!
Thanks again Ryan!
I'll get some pictures of the spacers up shortly... but your A-Arms should have them?
Glad to help and I don't think you will have any issues, also the iron block won't hurt them at all. I attached a picture of the measurement... nothing fancy, I just made it quick. So use 1" on the poly end and 7/8" on the rod ends... the A-Arms are pre-set but most likely have moved.
Hope this helps!
Ryan
Thanks again Ryan!
Thanks again Ryan!
Hope this helps!
Ryan
Hope this helps!
Ryan
Hope this helps!
Ryan
--Sorry, not trying to be difficult, just trying to get my understanding down. Your picture makes perfect sense, it just contradicted my original understanding. Just trying to get it right.
Thanks Ryan!
Hope this helps!
Ryan
Hope this helps!
Ryan
also i too will be send back my rod ends for your poly. and thanks for the pictures
How long have the spacers been included with the A-arms?
I had mine probably around 1 year and didn't get any spacers, but I haven't not had any problems with my A-arms.
By the way, are they available on the UMI performance website yet? I checked but I couldn't find them myself.
Awesome, thanks for the picture. That helped out. So you want 1" of thread engagement for the poly end and .875" (7/8") on the rod end? When I called and talked to your tech, Jerry I believe his name was, I thought he said that you measured that distance from the bottom of the jam nut outward, towards the bushing, and that distance was 7/8" for both.
Hello
Yes on the poly bushing you want the spacing of 1' and with the rod ends you want a 7/8 spacing from the jam nuts to the threaded end that gets screwed in.
Thanks Ryan!
Hello
Thanks Ryan!
Thanks
Brad
