Whats double clutching???
Old 09-03-2009, 09:33 PM
TROPIC_THUNDER's Avatar
Default Whats double clutching???
What does it mean when I hear people say they double clutch when racing?? Thanks
Old 09-03-2009, 09:46 PM
the_merv's Avatar
You'll probably get like 10 different answers for this..
I know what it is for driving with a non-synchronized Tranny..that is what I've always known.
Old 09-03-2009, 10:26 PM
happysem's Avatar
I thought it was not used in racing, but you would shift into neutral, let off clutch, then push it back in to engage to the next gear...seems pointless to me if you're trying to go fast.
But I don't think thats what you're talking about.
Old 09-03-2009, 10:31 PM
the_merv's Avatar
That's the way I know it.
Old 09-03-2009, 10:47 PM
lt1badbird's Avatar
probably just got done watching the fast and the furious
Old 09-03-2009, 10:52 PM
Slvr00Bird's Avatar
The opposite of granny shifting..
Old 09-03-2009, 10:56 PM
lt1badbird's Avatar
"your granny shifting and not double clutching like you should"!
Old 09-03-2009, 11:48 PM
1BADAIR's Avatar
yep
clutch, pop out of gear, release clutch, press clutch and upshift
basically it spools the trans to engine speed so you can shift a non syncro trans
I do this on the street with my faceplated t56
Old 09-03-2009, 11:57 PM
mediocrels1's Avatar
Originally Posted by 1BADAIR
yep
i thought u only had to do it when down shifting?
Old 09-04-2009, 12:15 AM
1BADAIR's Avatar
you don't HAVE to do it.
just causes less wear and is a little smoother
Old 09-04-2009, 12:28 AM
lemons12's Avatar
Default !:)
just if you wanna be F&F
Fixed~
Old 09-04-2009, 12:33 AM
hitmanws6's Avatar
its what you should do when you have 2 huge bottles of NAWS in the back
Old 09-04-2009, 08:15 AM
the_merv's Avatar
I remember that.. FAIL.
Old 09-04-2009, 08:20 AM
PewterScreaminMach's Avatar
Clutch in, shift into neutral, clutch out, rev up the motor to get the trans internals spinning to the appropriate revs matching the engine, clutch in, shift into gear, clutch out. It's a technique used in transmissions that do not have synchros where the speed of the engine and transmission internals needed to be closely matched on shifts so that you wouldn't grind going into gear.
There is an excellent article here (http://auto.howstuffworks.com/transmission.htm) that explains the internals of the manual transmission very well with simple diagrams and interactive illustrations. On page 3, there is a great explanation of what double clutching is. I highly recommend you read this article and especially page three if you want to know what double clutching really is, rather than listening to the various false information that so easily spreads throughout the forums. Page 4 explains synchros.
Anyone who truly understands what double clutching is would realize there is no legitimate purpose for doing it in a car that has a synchronized transmission (ie our cars), unless you're really that worried about wearing down the friction cones in the synchros. I've only once ever seen a friction cone go out, though (and of course it was in my car...).
Old 09-04-2009, 08:26 AM
registered user
ScreaminRedZ's Avatar
Originally Posted by lemons12
Fixed~
Haha, that's awesome.
I prefer the shifting method where I put a brick on my gas pedal, then I put both feet on the dashboard, grab that shifter with both hands and yank it into the next gear no matter kind of sounds the transmission makes.
Takes a man to use this method though
Old 09-04-2009, 01:18 PM
lemons12's Avatar
I LOL'd!
Old 09-04-2009, 01:21 PM
happysem's Avatar
Ok, but why not just rev match?
clutch in, put RPMs at whatever speed, shift, and clutch out?
Old 09-04-2009, 04:38 PM
Taken4granted's Avatar
ScreaminRedZ thats f'k hilarious
Old 09-04-2009, 06:59 PM
bigti99a's Avatar
Originally Posted by screaminredz
haha, that's awesome.
I prefer the shifting method where i put a brick on my gas pedal, then i put both feet on the dashboard, grab that shifter with both hands and yank it into the next gear no matter kind of sounds the transmission makes.
no doubt! Grip it and rip it!!!
Old 09-04-2009, 11:20 PM
1BADAIR's Avatar
Clutch in the input shaft isn't spinning. Rev matching is matching engine rpm to trans/vehicle speed. Double clutch spins the cluster shaft back to engine speed
