Using a Rear mount will it help or hurt deleting the cats?
Old 09-04-2009, 08:13 PM
vipvegas's Avatar
Default Using a Rear mount will it help or hurt deleting the cats?
As described thinking about getting precat eliminator pipes?
Old 09-04-2009, 09:45 PM
black98ws6ta's Avatar
They need to be deleted or they will end up going through the turbo's.
Old 09-04-2009, 11:02 PM
vipvegas's Avatar
thats why I asked cat on driver side honeycomb is all cracked..
Old 09-05-2009, 07:51 AM
mcx
mcx's Avatar
delete em...my car felt much better without the cats... heat wrap the replacement pipes!
Old 09-05-2009, 10:19 AM
vipvegas's Avatar
I only found one set of pipes pre made by mufflex. Do you guys just have someone fab them up or what?
Old 09-05-2009, 12:53 PM
RooRnZ28's Avatar
try the bassanini ory.. it pretty much just bolts right in place of the stock catted y
Old 09-05-2009, 03:35 PM
vipvegas's Avatar
I have the slp y, Im talking about the precats where the manifolds bolt up.
Old 09-05-2009, 03:39 PM
hawk584's Avatar
do you have emission tests in FL? i also have heard cats breaking down and damaging the turbo blades. you could gut or make some dummy looking cats to pass a visual
Old 09-05-2009, 05:39 PM
vipvegas's Avatar
no smog here. I hear gutting is a pain.. Wish I knew someone with a bender cause these bends arent bad at all.
Old 09-05-2009, 07:19 PM
V-seriesTech's Avatar
Gutting cats?
Prybar,block of wood, hammer, elbow grease. Oh,...and a mask,broom,and dust bucket. Don't let any gay dudes see you with all the pretty glitter all over you.
Old 09-05-2009, 10:22 PM
vipvegas's Avatar
I thought about cutting around cat and taking the honeycomb out then re weld it.
Old 09-05-2009, 11:00 PM
VIPERKLR's Avatar
yeah just cut it out knock it out and weld back in took me 45 mins on the ground in my driveway
Old 09-06-2009, 08:51 AM
JAX04's Avatar
plus 1 bazillion, delete those cats!! lol bad for tubo
