can i buy procharger mounting hardware?
Old 09-05-2009, 08:24 PM
Taubr Unit's Avatar
Default can i buy procharger mounting hardware?
This ****** **** NEVER ends!!!
So after drilling and tapping the block i go to finally mock up the head unit and now i dont have the ****** mounting hardware. I need the 3 spacers to space it away from the alternator and the 2 long threaded rods etc. Basically everything to mount the J-bracket. I sent a PM to Bob@EPP just waiting to hear back. In the meantime does anyone know if i can even buy them and for a ballpark price??
Old 09-05-2009, 10:09 PM
JC70SS's Avatar
call Bob pm will take a WHILE!
Old 09-05-2009, 10:14 PM
jomomma's Avatar
you can buy them form epp or procharger directly
Old 09-05-2009, 10:26 PM
Taubr Unit's Avatar
Well that's good to know, hopefully I don't need to sell my left nut for this **** or hopefully it doesn't come as part of a kit with 99% of **** I don't need. Ill try n call bob Tuesday.
Old 09-05-2009, 11:30 PM
MelScrilla's Avatar
just stick with it your almost to the end now
Old 09-06-2009, 12:19 AM
9silverbird8's Avatar
Its just threaded rod, rod couplings, and some bolts and washers. Easy to find at the home depot or alike.
or
http://www.exoticperformanceplus.com...html?item=1472
Old 09-06-2009, 12:29 AM
Taubr Unit's Avatar
or
thats exactely what i need, thanks! I tried looking for threaded rod but id have to order it. Its 10mm X 1.5 pitch metric. Cant get at any hardware store and if it was it be real cheap *** ****, the last thing i would want to hold on a blower. PLUS the spacers gotta be dead on or belt alignment would suck, also the last thing you want for a blower belt. Thanks for the find though, last thing is thats for the 6 rib pully and mine is 8 rib. Im assuming the spacing is a tad different for the thickness of pullies
Old 09-06-2009, 12:37 AM
TWS
TWS's Avatar
Yes, the 8 rib and 6 rib standoffs and threaded rods are different. I'm nearly done with a 6 rib to 8 rib conversion, so I just went through all of that.
Too bad you need 8 rib. I just boxed up all of my 6 rib stuff and it's sitting on the shelf.
Old 09-06-2009, 12:38 AM
Taubr Unit's Avatar
ok well that settles that. Did u buy the 8 rib **** or make it?? Fill me in here bro because its showing the mounting hardware on EPPs site for the 8 rib the same as the 6 rib.
Old 09-06-2009, 01:00 AM
TWS
TWS's Avatar
I purchased the 8 rib conversion kit from Bob, but he had it shipped to me directly from Procharger. I have all of the paperwork out in the garage that give the sizes, etc. If you want to make your own, I can grab it tomorrow and post the dimensions.
The 8 rib mounting stuff is definitely different. It's longer and pushes the J-bracket a little further out from the block. Not sure if this is relevant to you but the 8 rib crank pulley mounts differently than the 6 rib. I had to buy an ATI damper and then source my own bolts to mount the A/C pulley (from ATI), the ATI damper, and the Procharger 8 rib crank pulley all together. The bolts from both Procharger and ATI are not long enough for cars that want to keep A/C.
Old 09-06-2009, 01:05 AM
Taubr Unit's Avatar
i have everything, it all came with the kit its just that my dumbass lost all the hardware. I have all the pullies, brackets etc just no way to mount the ****. And actually i have one spacer off the alternator bracket. I see they list them part by part with p/n's. Wonder if i can just order only what i need. Guyss i wont know till i talk to bob, but worst comes to worse i buy the entire 8 rib kit for $60 and be done with it. To me $60 is well worth it for no headachs!!!
Old 09-06-2009, 10:29 AM
I just upgraded to SDCE 8 rib from a 6 rib setup and used all the same hardware. Its real easy to use shims to space the bracket the extra 1/4'' or so that you need.
Old 09-06-2009, 10:44 AM
Taubr Unit's Avatar
I hope i dont have to do that, that would kill the quality of this **** if i need to start shimming stuff out. That never looks good. ****
Quick Reply: can i buy procharger mounting hardware?
