Pacesetter Header Install
Old 09-06-2009, 10:53 AM
Marinez28's Avatar
Default Pacesetter Header Install
Need a question answered. Putting the pacesetters in. Driver side done and no issues. Passenger side...the collector is hitting the heat shield not allowing the bolt holes to line up. I removed it and now they line up. Question is can i leave the shield off and just bfh the floor pan a little to make more clearance?
Will this cause any heat issues?
Old 09-06-2009, 10:55 AM
00ssSLP's Avatar
I used a little header wrap on my car. last I knew this could be found at Advance Auto Parts and I think Auto Zone.
Old 09-07-2009, 12:38 AM
bongva's Avatar
nope should be fine, i have had my car with no heat shield for about a year now, and have had no problems
Old 09-07-2009, 01:55 AM
2002 SS's Avatar
nothin wrong with a little BFH lol. Weird my pacesetters went in like butter. good luck!
Old 09-07-2009, 02:29 AM
BluShadowSS's Avatar
it should go in without removing the heatshield.
Old 09-07-2009, 03:33 AM
IWGF's Avatar
+1, my pacesetters went in ****** easy and cherry. Weird.
Old 09-07-2009, 05:23 AM
jetlag's Avatar
That's weird... usually the passenger side headers fits in like a hotdog down a hallway...
Old 09-07-2009, 11:26 AM
WSsick's Avatar
mine went in so easy, it pissed me off that the driver's side takes a good amount of fanagling.
Old 09-07-2009, 11:33 AM
Marinez28's Avatar
I don't know, maybe its different on each car. My driver's side went right in with no problems ceptshaving a little off the casting tab. The passenger side gave me a little trouble: had to jack it up a few more inches, took off that heat shield and a little clearencing with the bfh and its good. I should have done this a long time ago, those long tubes really wake up the car!
Old 09-07-2009, 11:37 AM
MattxFatal's Avatar
WTF.
My passenger side is retarded.
Driver side needs a little bit of work.
But that God damn passenger side...
Old 09-07-2009, 01:13 PM
Marinez28's Avatar
Passenger side takes patience once you get the header in and start putting things back together. Fortunately my wife likes to wrench and she helped out alot with her little hands and small arms! Made life alot easier!
